Drop the trans, or the whole thing. |
TheCabinetmaker |
Jun 22 2010, 07:00 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I've had either a rear crank seal or a trans input shaft seal, or both, leaking for some time now. Clutch has been slipping slightly, and I've been babying it. Yesterday the clutch gave it up. I also need to replace pushrod tube seals and motor mounts. I'm presently building a 2056 with Raby 9550 cam, so I'll be swapping engines in the near future. The swap will be a complete long block, tin and all. Pull engine, install trans, and install new engine. Now to my dilemma.
Should I, 1. pull the trans and replace seals and clutch only and drive? 2. pull engine and trans, replace seals, clutch, and pushrod tube seals 3. Pull it all and wait for the new motor and drive the truck? |
Tom |
Jun 22 2010, 07:06 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Curt,
If mine was a daily driver, I would chose option 1. Option 2 is possible also, but you know what happens when you start tearing into these cars - while I'm in there disease. How far in the future is the new engine? If soon, definitely option 1. Tom |
Lo-Fi Version | Time is now: 11th June 2024 - 11:19 PM |
