Adding torsional rigidity, How do I get the front half tight? |
phillstek |
Jun 23 2010, 06:39 AM
Member Group: Members Posts: 350 Joined: 19-May 10 From: Byron Bay, Australia Member No.: 11,741 Region Association: None |
Once again I prevail upon the expertise here.
I have stiffened the rear of the car substantially, as shown in pics. Tubes go from rear towers through engine bay and firewall to rollbar. Rollbar is plated to longs and strapped to upper seat belt mount. There is a lateral bar (profiled to clear fan housing) in the engine bay. Car has the plates around the control arm consoles as well. So the back end is solid but I'm not sure how to get the front section solid. I'm thinking a bolt-in bar triangulating as far forward from rollbar to long (one each side like on some factory gt's). Maybe a bolt-in from front towers to rollbar (through fresh air vents, which don't work anyway). I don't want to weld in the bars as I won't be able to road register the car if I do. I don't want to re-inforce the longs with a weld in kit. The car seems to move around the scuttle and I have cracked a windscreen to prove it. Clearly the car twists in this area and this is what I want to stop. Any suggestions, links and advice would be appreciated. Thanks, Phil |
phillstek |
Jun 23 2010, 03:10 PM
Thanks to all for replies.
Car has 6 point comp harness for both occupants and I have retained the original retractables as well. What about a bar that ties the longs together at the front that goes up under the dash (like rollbar but hidden from view..welded) Then attached to upper front towers through firewall continued to front trunk suspension pick-up points?. Add a couple of door bars (bolt-in) and that should help right? The authority that governs road registration does not allow bars foward of where my rollbar is and the vehicle requires annual inspection for road use. Thanks, Phil Attached image(s) |
Lo-Fi Version | Time is now: 11th June 2024 - 11:16 PM |
