#1 cylinder?, On distributor? |
raw1298 |
Jun 28 2010, 08:42 AM
Senior Member Group: Members Posts: 616 Joined: 9-March 09 From: Rocklin,Ca. Member No.: 10,148 Region Association: Northern California |
As you are looking at the top of the distributor, is the first contact to the right of the vacume advance the spot for the #1 cylinder wire? I did not map it out when I took engine apart. (IMG:style_emoticons/default/sad.gif)
dr914@autoatlanta.com |
Jun 28 2010, 08:58 AM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
As you are looking at the top of the distributor, is the first contact to the right of the vacume advance the spot for the #1 cylinder wire? I did not map it out when I took engine apart. (IMG:style_emoticons/default/sad.gif) should be at the 10 oclock position when the vacuum advance is facing at about the 7 oclock position. |
Lo-Fi Version | Time is now: 11th June 2024 - 01:35 AM |
