#1 cylinder?, On distributor? |
raw1298 |
Jun 28 2010, 08:42 AM
Senior Member Group: Members Posts: 616 Joined: 9-March 09 From: Rocklin,Ca. Member No.: 10,148 Region Association: Northern California |
As you are looking at the top of the distributor, is the first contact to the right of the vacume advance the spot for the #1 cylinder wire? I did not map it out when I took engine apart. (IMG:style_emoticons/default/sad.gif)
ME733 |
Jun 28 2010, 03:32 PM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
............Well , consider all the good advise here....and consider this.....With the engine at top dead center (TDC) on number ONE (1) cylinder.....the ROTOR button will be pointed to the nose of the crankshaft at the front of the engine...and the "notch" on the distributor, and the Rotor button will also be lined up .....However all this is dependant on weather the distributor drive has been installed correctly........AND when assembling an engine, with a degree wheel on the front of the crankshaft,....you can rotate the distributor ROTOR,(and with voltmeter hooked up)....you can determine how much ignition ADVANCE your particular distributor has.
Lo-Fi Version | Time is now: 11th June 2024 - 07:44 AM |
