#1 cylinder?, On distributor? |
raw1298 |
Jun 28 2010, 08:42 AM
Senior Member Group: Members Posts: 616 Joined: 9-March 09 From: Rocklin,Ca. Member No.: 10,148 Region Association: Northern California |
As you are looking at the top of the distributor, is the first contact to the right of the vacume advance the spot for the #1 cylinder wire? I did not map it out when I took engine apart. (IMG:style_emoticons/default/sad.gif)
raw1298 |
Jun 28 2010, 03:40 PM
The engine was running when I got it out of a donor car. The distributor was never taken out. I just could not remember which plug wire went where. I found a picture in one of the other threads and found I was 1 spot off from where each wire went. I changed them all to where they should go.
rwilner |
Jun 28 2010, 06:16 PM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
This thread may or may not confuse the issue:
http://www.914club.com/bbs2/index.php?showtopic=209425 scroll to the last post to see a pic of how it SHOULD be. bottom line: if you find TDC for cyl 1 on the power stroke (via any method you like), whatever plug tower the rotor is pointing at is for the #1 wire. If your dizzy gearing is installed as the factory intended, at TDC for #1, the rotor will be pointing at the scribe on the dizzy body (cap must be removed to see the scribe). good luck! |
Lo-Fi Version | Time is now: 11th June 2024 - 07:37 AM |
