| rick 918-S |
Jul 10 2010, 07:55 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,279 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
I have decided to restore the Raspberry car as close to Concours as I can. I have an engine bay sound pad that is very nice. I mean really nice. One problem though. The pad is glued and held in place with plastic retainers. Over time, the pad holds moisture against the firewall and will cause rust. This actually happened to this car and the Ravenna car I have causing rust holes in the firewall. Here in MN we have cold wet winters and damp humid summers. It is very likely if I just do what the factory did to install the pad the process of rust will just start over.
My question is: You guys that have completed a concours quality car must have thought about this. What have you done to prevent the creep of rust that starts behind the pad? I'm working on a couple ideas that I think will work without causing the judges to freak out. I thought about trying bed liner. The stuff is near bullet proof in the bed of our Titan. I haven't even been able to scratch it. The glue that is used to secure the pad should not be able to penetrate the bed liner which is what I think is happening to the painted finish behind the pad. The glue will break down over time causing the loss of paint that it is stuck to. The moisture in the pad will start the rust process. The rest is history. BTW: I would only be using this on the firewall and it will be completely hidden by the back pad. Cool? or Lame? I also thought about thinning out some fibre glas resin with laquer thinner and carefully wetting the fiber that contacts the firewall. This way moisture would not be absorbed anymore. (IMG:style_emoticons/default/confused24.gif) just thinkin out loud. |
| rick 918-S |
Jul 10 2010, 11:48 PM
Hey George, Gots any photos of your pad installed? Any experience with the concours police?
rick 918-S Has this been discussed? Engine bay sound pad Jul 10 2010, 07:55 AM
dr914@autoatlanta.com we install out dynamat new factory identical pad t... Jul 10 2010, 08:09 AM
rick 918-S
we install out dynamat new factory identical pad ... Jul 10 2010, 09:02 AM
watsonrx13
we install out dynamat new factory identical pad ... Sep 5 2010, 04:23 PM
Jeff Bowlsby I like the idea of the fiberglass coating Rick. J... Jul 10 2010, 08:40 AM
rick 918-S
I like the idea of the fiberglass coating Rick. ... Jul 10 2010, 09:05 AM
Tom_T Hey Rick - you saw what happened to the firewall/e... Jul 10 2010, 10:04 PM
96740 When I was having my engine rebuilt I was seriousl... Jul 10 2010, 10:19 PM
scotty b Rick, my concern with bedlining the wall first, wo... Sep 5 2010, 05:54 PM
Pat Garvey
I have decided to restore the Raspberry car as cl... Sep 6 2010, 07:13 PM
McMark Could you remove the 'hair' and glue what... Sep 6 2010, 11:30 PM
rdauenhauer I cleaned and cleaned and cleaned mine, then just ... Sep 20 2010, 10:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 02:27 AM |
