electrical questions, replaced fuses, then... |
double-a |
Mar 13 2004, 11:32 PM
Senior Member Group: Members Posts: 987 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest |
i replaced all the fuses on the fuse block today, many looked quite sorry indeed. now, after doing so, the headlights do not rotate up or turn on, no fog lights, and no wipers either. on the front of the fuse panel, all fuses are good, and i think they're all in their correct places. on the backside, everything looks good. there is, however, a wire up under the dash, near the fuse panel but not connected to it, that is a single spade with four brown wires. does this go anywhere on the block? and if not, what would happen if it had touched something on the back of the fuse panel?
thanks for any help. i did consult the color wiring diagrams, they are little help to me unfortunately. i'm good mechanically, but not much of an electrician. i would very much like for my headlights to work! ~a |
ejm |
Mar 14 2004, 05:59 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Multiple brown wires into one connector sounds like the grounds near the fuse box.
There should be a 6mm stud on the inside of left bracket that the fuse box mounts to. If it has broken off any good ground to the body will work just as well. |
Lo-Fi Version | Time is now: 11th June 2024 - 12:23 AM |
