| rick 918-S |
May 24 2010, 11:39 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,368 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
Not much to report yet other than I'm really excited about the car. I can't say why but I haven't been this interested in a car in years. Back in 2006 when I picked up the other Raspberry car from Britt I did some research on the color. It is actually listed as "strawberry" in the Du Pont line of finishes. I think DaveP even told us that but we never really changed it. We all have been calling the color Raspberry so long now I can't bring myself to change it now. So as far as I'm concerned these are the berry sisters.
I sprayed out some test panels over the weekend with the idea in mind to have the acrylic enamel scanned and have the color mixed in single stage urothane. I went to the paint store and had it scanned. I had a pint mixed and I am going to spray out a couple more panels to check the color conversion. I damn near died when I was told a gallon of color will cost near $ 800.00! This is before the reducer/activator! The pint I purchased today was like $ 110.00! ouch! Well anywho, Here's the place for the progress reports. I hope to really get into this car by late August. We shall see. ![]() |
| Rob-O 1167 |
Jul 14 2010, 09:51 PM
Member ![]() ![]() Group: Members Posts: 54 Joined: 19-April 09 From: Mansfield, TX Member No.: 10,280 Region Association: None |
I'd have to disagree with the dipping...of any kind. For that to be the case the car would have to be dipped with the longs not welded in, then the heater hoses attached, then the outer long welded on. Welding after dipping would mean grinding paint around the area where the weld of the outer longs would take place. It would also negate the reason for dipping in the first place, which is to get to areas you can't normally get to once the frame/body is assembled. Also, dipping is not perfect. In other words, paint flows off the frame once it's pulled from the tank. We would undoubtedly see some small runs from the dip process and I've yet to ever see them on a 914.
rick 918-S Raspberry 914 build starts May 24 2010, 11:39 PM
plymouth37 Very cool, Keep us updated! May 25 2010, 06:31 AM
rick 918-S I just received the title in the mail from Jason i... May 25 2010, 07:25 AM
Sleepin :drooley:
Man, I can't wait! May 25 2010, 07:27 AM
jasons I think Porsche lists the color as Fraise, which t... May 25 2010, 07:51 AM
Bartlett 914
$ 800.00! This is before the reducer/a... May 25 2010, 08:26 AM
Root_Werks Does that color make anyone else hungry for ice cr... May 25 2010, 08:40 AM
Teknon
Does that color make anyone else hungry for ice c... Jun 13 2010, 09:04 PM
bugsy0
Does that color make anyone else hungry for ice c... Jun 19 2010, 12:17 AM
rick 918-S Even though I have not had time to really work on ... May 25 2010, 08:50 AM
rick 918-S Since Sir Andy's ISP was unable to figure out ... Jun 13 2010, 07:35 PM
Krieger914 I had a 64 Ghia that I painted Rasperry back in th... Jun 13 2010, 07:39 PM
rick 918-S I didn't want to loose the door jamb sticker a... Jun 13 2010, 07:41 PM
rick 918-S When I opened the head lights to start pulling the... Jun 13 2010, 07:47 PM
BigDBass :D :popcorn: Jun 13 2010, 07:49 PM
rick 918-S Every piece of plastic and rubber on this car are ... Jun 13 2010, 07:50 PM
rick 918-S Dash pad, windsheild trim and glass is out. I ende... Jun 13 2010, 07:55 PM
davep Fraise it is, but that is French for strawbery. So... Jun 13 2010, 08:57 PM
rick 918-S
Fraise it is, but that is French for strawbery. S... Jun 13 2010, 09:01 PM
jasons
Fraise it is, but that is French for strawbery. ... Jun 13 2010, 10:20 PM
rick 918-S BTW: I can't tell yet whether the dash frame w... Jun 13 2010, 09:08 PM
jmill I have 2 that same color in spots. I assumed it w... Jun 13 2010, 09:13 PM
rick 918-S
I have 2 that same color in spots. I assumed it ... Jun 13 2010, 09:18 PM
rick 918-S Here's another example of the amount of heat t... Jun 13 2010, 09:15 PM
carr914
$ 800.00! This is before the reducer/... Jun 14 2010, 07:26 AM
rick 918-S I bought a new tool today. I went to Harbor Freigh... Jun 18 2010, 07:45 PM
rick 918-S Inside the front trunk..
Jun 18 2010, 07:48 PM
rick 918-S As I was stripping things off the car I discovered... Jun 18 2010, 07:58 PM
jasons
As I was stripping things off the car I discovere... Jun 18 2010, 11:26 PM
rick 918-S
As I was stripping things off the car I discover... Jun 18 2010, 11:41 PM
iamchappy Yum Yum a Raspberry Soda sounds refreshing on a ho... Jun 18 2010, 08:00 PM
rick 918-S I picked up a really cool Blaupunkt AM/FM from Jef... Jun 18 2010, 08:04 PM
bembry I've missed the history on this car if in anot... Jun 19 2010, 07:15 AM
rick 918-S
I've missed the history on this car if in ano... Jun 19 2010, 07:49 AM
jasons
I have two of the three cars known.
Actually, ... Jun 19 2010, 08:39 AM
McMark You're soooooo greedy, Rick. :stick: Jun 19 2010, 08:50 AM
Sleepin Rick has obviously been sharing his paint secrets ... Jun 19 2010, 06:27 PM
jmill That is very nice. Feel free to bring that soda b... Jun 19 2010, 07:38 PM
rick 918-S
That is very nice. Feel free to bring that soda ... Jun 28 2010, 04:35 AM
rick 918-S I worked on the trunk floor repair panel. I decide... Jun 28 2010, 04:42 AM
9146986
This is not nessesary as these are really only u... Jun 28 2010, 01:07 PM
This is not nessesary as these are really only u... Jun 28 2010, 02:18 PM
rick 918-S If you notice there is a dimple on the edge of the... Jun 28 2010, 04:49 AM
SirAndy Any chance you'd consider adopting me?
:D A... Jun 28 2010, 12:03 PM
RobW
:D ... Jun 28 2010, 12:20 PM
BigDBass Rick, my 914 says it misses you and MN and wants t... Jun 28 2010, 01:18 PM
rick 918-S No dipping as far as I know or we wouldn't be ... Jun 28 2010, 02:54 PM
McMark They were dipped in primer, but the paint was spra... Jun 28 2010, 06:27 PM
Sleepin :D
http://cgi.ebay.com/ebaymotors/1993-Porsch...... Jul 14 2010, 09:15 PM
McMark I respect your right to disagree, but I know I... Jul 14 2010, 09:53 PM
rick 918-S Crazy busy with work stuff but the muffler heat sh... Jul 14 2010, 10:22 PM
Rob-O 1167 Research Karmann a little. I think you'll fin... Jul 15 2010, 07:46 AM
Rob-O 1167 And Rick, the ride looks great! Awesome color... Jul 16 2010, 06:42 AM
rick 918-S Ok fellas, I had an inquiry about this car and tho... Nov 2 2014, 06:32 PM
RobW Very nice! :headbanger: Nov 2 2014, 07:26 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd November 2026 - 05:34 PM |
