| brandomc |
Jul 19 2010, 10:17 AM
Member ![]() ![]() Group: Members Posts: 113 Joined: 14-May 09 From: los angeles california Member No.: 10,363 Region Association: Southern California |
Hi everyone, it has been a while since i posted on here. Last time i was having issues with a used 1.7 i put in my car. Since then, i built a 2056 and got the car running and driving. As i was out breaking in the engine my coil vibrated loose, slid into my throttle linkage and shorted out my ignition system. The positive wire to the coil melted and combined itself with the negitive coil wire. I pulled the engine harness out of the car and fixed the two wires that got toasted, but now the car has no power to the coil when i turn the key on. I have been trying to use the wiring diagrams in the haynes manual to trace the circuit, but i have been unable to figure it out. Those wiring diagrams suck, they look like they were photo copied 3 or 4 times before they made it into the manual.
I also pulled my relay board and did a continuity test to at all the corisponding terminals and the board checks out ok. Im not sure where to go from this point. It doesnt look like there are any fuses anywhere for this circuit. There are some other electrical issues too, but getting the car running is #1 priority. I pulled the fuse pannel down from the dash and the wires that hook to the fuse for the blinkers were melted. The blinkers havent been working on the car, so somewhere there is an issue with that circuit as well. Ignition circuit first though. Anyone have any expertise in this area?? Please help. I must show these gremlins who is really in charge!! |
| brandomc |
Jul 19 2010, 11:00 AM
I forgot to mention that when i turn the key into the on position, none of the warning lights on the dash light up. If i jump a wire from the positive terminal on the battery to the positive on the coil, all the warning lights work and the car starts and runs. I just cant turn the car off.
| Spoke |
Jul 19 2010, 11:19 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,370 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
I forgot to mention that when i turn the key into the on position, none of the warning lights on the dash light up. If i jump a wire from the positive terminal on the battery to the positive on the coil, all the warning lights work and the car starts and runs. I just cant turn the car off. Yikes, this is not good. What you are doing is power the car instead of from the ignition key, from the wire from the coil. You may have toasted either the ignition switch or the wire from fuse #8 to the ignition switch pin 15. Do test 4) from my previous post and let us know what you find. You do have a voltmeter right? If not, go buy one you will need in on future electrical issues. |
brandomc Wiring geniuses needed. Electrical gremlins Jul 19 2010, 10:17 AM
turnaround89 Is it just the coil not receiving power, will your... Jul 19 2010, 10:35 AM
brandomc
Is it just the coil not receiving power, will you... Jul 19 2010, 10:45 AM
brandomc
I forgot to mention that when i turn the key int... Jul 19 2010, 11:31 AM
SirAndy i am prety good with wiring when i have good diagr... Jul 19 2010, 12:10 PM
brandomc
i am prety good with wiring when i have good diag... Jul 19 2010, 12:47 PM
Spoke Hopefully i dont sound like an idiot by hooking up... Jul 19 2010, 02:34 PM
brandomc
Hopefully i dont sound like an idiot by hooking u... Jul 19 2010, 03:07 PM
Spoke The best I can tell there is no fuse in line with ... Jul 19 2010, 11:11 AM
turnaround89 Pulling the ignition switch is fairly straight for... Jul 19 2010, 05:38 PM
brandomc Well, last night i was able to find the problem in... Jul 20 2010, 11:14 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:28 AM |
