| avidfanjpl |
Jul 21 2010, 03:22 PM
914 Hemophiliac ![]() ![]() ![]() Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region |
OK, thinking caps, please.
The car sounds great and is strong on acceleration, but it is like there is a slight, and I mean almost not audible, snap/pop on high rev deceleration. And it does not occur such that it is rev related. It might be some kind of post-ignition detonation in the exhaust system. I had the valves lashed 400 miles ago, and there is no obvious sound of tapping or leaks. I know burned, bent valve sounds, and the engine would not perform like it is with a valve or a burned piston. I know those effects. I have good hoses to the decel valve, which is tested and working. I have no exhaust leaks that I can hear. It idles perfectly. This is a Dansk correct 2.0L muffler. Nearly new. Finished in Wurth Zinc Silver. My detailer and I took off the muffler and reinstalled it perfectly to fix the detent bolt on the speedo. We used new bolts on the headers/muffler, and the gaskets are not new but almost new and not even worn. I checked all the head exhaust bolts. No sign of a leak. No loose anything. Shook the pipes to see if one was loose. I am thinking it could be tin inside the Dansk??? Would once-used almost new exhaust gaskets cause a minor leak? They were bolted to correct torque specs. Also does not seem like the heat shield is loose above the Dansk. Any ideas? Anything? Thanks! John avidfanjpl |
| Ferg |
Jul 21 2010, 03:57 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None
I would first pinpoint location of the sound, if it truly is coming out the tailpipe it could be any number of things, engine tune related.
Since you said it's not rpm dependent, and on high rpm decel it could be some tin or other loose item that only makes contact when the motor/trans move/rock on their mounts? Ferg |
avidfanjpl Deceleration Exhaust Rattle Jul 21 2010, 03:22 PM
Tom_T John - IIRC it's new exhaust system gaskets wh... Jul 21 2010, 03:28 PM
avidfanjpl I can do something Saturday, Tom.
Any other idea... Jul 21 2010, 03:37 PM
avidfanjpl Thanks, Ferg!
There is no doubt in my mind th... Jul 21 2010, 04:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 27th September 2026 - 04:42 PM |
