> New motor ideas, 2.0 liter rebuild (or bigger)
realred914
post Jul 21 2010, 09:20 PM
Group: Retired Members
2.0 liter four is apart, needs work. would like some performance upgrade while it is being gone thru. thinking of a displacemnt increase. would like ot be able to run the D-Jet still.
what are the piston size options? draw backs of any (are cylinder walls too thin on any of thge big bore sets? is case machinging required? etc..
what are best brands?
also ideas on valve sizes and cam selection would be appreciated.
looking for a modest perfromance boost, but still able to retain the D-jet system
already have the ealry 2.0 liter exhaust system.
let me know what you all have done, and what is available.
thanks
orange914
post Jul 21 2010, 10:23 PM
http://5starmediaworks.com/index.html
if you want to spend the time & energy you can get some good deals on the needed parts to do it yourself here. off the top it sounds you'll basically need:
20 longblock and the (2) tin peices for 2.0 914 heads
do you have the 2.0 intake runners/manifold w/ your 2.0 d-jet?
have the m.p.s. tuned (for 2056)
bore the 94mm to 96mm jugs (for a 2056)
have decks & line bore checked
jake 9550 or comp. web cam
extras like these are what i did & really worth it in my book:
balance rotating ass.
lighten flywheel to 11 lbs.
get titanium (i think... duh...) and set the valve train geometery
pertronix or simular electronic ignition
realred914   New motor ideas   Jul 21 2010, 09:20 PM
rick 918-S   Jake or McMark   Jul 21 2010, 09:33 PM
orange914   as far as i know the early d-jet (if it's 1.7)...   Jul 21 2010, 09:46 PM
realred914   as far as i know the early d-jet (if it's 1.7...   Jul 21 2010, 09:54 PM
Tom_T   IIRC - the "Raby 2056 kit" upbuild that ...   Jul 21 2010, 09:53 PM
DanT   take the 94 mm cylinders and have them punched out...   Jul 21 2010, 09:56 PM
realred914   take the 94 mm cylinders and have them punched ou...   Jul 21 2010, 10:00 PM
tradisrad   take the 94 mm cylinders and have them punched o...   Jul 22 2010, 07:23 AM
realred914   [quote name='realred914' post='1346366' date='Jul...   Jul 22 2010, 09:45 AM
DanT   2056 is about it. anything larger like 2270 will ...   Jul 21 2010, 10:02 PM
jeeperjohn56   I did exactly what you want to do, I have a 73 2.0...   Jul 21 2010, 10:06 PM
orange914   if you want to spend the time & energy you can...   Jul 21 2010, 10:23 PM
Bleyseng   I have heard of a 103x71 motor working with Djet a...   Jul 22 2010, 06:39 AM
JmuRiz   Jake's combo for a 2056 can get you 120hp, wit...   Jul 22 2010, 07:57 AM
Jake Raby   Several years ago I proved that the capability of ...   Jul 22 2010, 10:01 AM
Bleyseng   If you want easy build a 2056 with 120hp and to b...   Jul 22 2010, 10:08 AM
realred914   If you want easy build a 2056 with 120hp and to ...   Jul 22 2010, 10:57 AM
Jake Raby   Then call me... :-) (sorry, couldn't resist...   Jul 22 2010, 11:05 AM
realred914   Then call me... :-) (sorry, couldn't resis...   Jul 22 2010, 12:39 PM
BK911   The 1.7 Djet wont work on a 2056?   Jul 22 2010, 05:46 PM
realred914   The 1.7 Djet wont work on a 2056? some parts c...   Jul 22 2010, 06:39 PM
Bleyseng   I could make the 1.7L intake setup work with 2.0L ...   Jul 23 2010, 04:48 AM
orange914   I could make the 1.7L intake setup work with 2.0L...   Jul 23 2010, 09:06 PM
Bleyseng   you can use the 1.8L Ljet too if you want and its ...   Jul 24 2010, 02:37 AM
- Lo-Fi Version Time is now: 11th July 2025 - 08:38 AM
