| Pat Garvey |
Jul 19 2010, 07:18 PM
Do I or don't I...........? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,900 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
While I'm waiting for parts for the gas tank switch, I thought I'd get started on another project that I've been putting off - intake tubes.
When I redid my originals in 1989, I made the mistake of clearcoating them. Man, did they look great for 7-8 years, before then engine heat took over. Still don't look horrible, but you can tell. So, I have two extra sets (eBay). Both are gross! I intended to refurbish both, but the red set has bad clips, so it will go in the trash tomorrow night. The other set - silver-on white-on gray look like the have potential. So, I started citris stripping them tonight. It's 86 degrees in the garage, so the stripping should be enhanced by the heat (unlike me). The red ones are free to anyone so inclined, but you need to let me know by tomorrow night! They are really crude. I must start throwing this stuff out. Pics attached Attached image(s)
| tod914 |
Jul 22 2010, 05:14 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Eric, if you take 800 to 1000 grit and wet sand it, you'll get a nice matt finish on them. Just don't use any polishes or compound after sanding. The scotch bright pads work well too for the harder to get areas. That's what I ended up doing with mine. I'm happy with the results. Nice color match btw. What RAL color is it?
Pat Garvey Next Resto Project Jul 19 2010, 07:18 PM
Bleyseng build yourself a soda blaster or a rust removal ta... Jul 20 2010, 12:56 PM
Pat Garvey
build yourself a soda blaster or a rust removal t... Jul 21 2010, 07:20 PM
windforfun Bad clips? How so? Jul 20 2010, 01:30 PM
Pat Garvey
Bad clips? How so?
Th top clips have been bent ... Jul 21 2010, 07:18 PM
type47 I sent mine to the powdercoaters and really like t... Jul 21 2010, 08:30 AM
Pat Garvey
I sent mine to the powdercoaters and really like ... Jul 21 2010, 07:11 PM
Sleepin I had mine powdercoated, they look great. I used 6... Jul 22 2010, 10:17 AM
Pat Garvey
Eric, if you take 800 to 1000 grit and wet sand i... Jul 22 2010, 06:43 PM
Pat Garvey
Eric, if you take 800 to 1000 grit and wet sand i... Jul 28 2010, 06:32 PM
Sleepin
Eric, if you take 800 to 1000 grit and wet sand i... Aug 6 2010, 06:54 PM
mepstein Pat - I appreciate what your doing to get your car... Jul 22 2010, 07:06 PM
Pat Garvey
Pat - I appreciate what your doing to get your ca... Jul 28 2010, 06:39 PM
tod914 I'll try to get some better shots for you Pat.... Jul 22 2010, 08:33 PM
tod914 Pat I don't think the powder will change over ... Jul 28 2010, 07:06 PM
Pat Garvey
Pat I don't think the powder will change over... Jul 30 2010, 06:32 PM
tod914 Will do Pat. Just need to organize them abit bett... Jul 31 2010, 09:04 AM
Pat Garvey
Will do Pat. Just need to organize them abit bet... Jul 31 2010, 07:07 PM
tod914 Pat bad email address
Hi. This is the qmail-send ... Aug 1 2010, 02:25 PM
MDG
Hi. This is the qmail-send... Aug 6 2010, 07:36 PM
tod914 Mike, I'll post them on the site here in case ... Aug 6 2010, 08:13 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 03:44 AM |
