realred914 |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None ![]() |
2.0 liter four is apart, needs work. would like some performance upgrade while it is being gone thru. thinking of a displacemnt increase. would like ot be able to run the D-Jet still.
what are the piston size options? draw backs of any (are cylinder walls too thin on any of thge big bore sets? is case machinging required? etc.. what are best brands? also ideas on valve sizes and cam selection would be appreciated. looking for a modest perfromance boost, but still able to retain the D-jet system already have the ealry 2.0 liter exhaust system. let me know what you all have done, and what is available. thanks |
BK911 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None ![]() |
The 1.7 Djet wont work on a 2056?
realred914 |
The 1.7 Djet wont work on a 2056? some parts can be made to work, the mps is adjustable if yu got the right cast casing on it(some allow more adjustment evidently) the injectors are probably too small, but you could likely drive the 2.0 liter injectors like the 73 2.o liter you may want the inline head temp resistor. the 2.0 liter d-jet is only seeing a less than 10% displacment increase with a 2050 motor, probably within the design limits of the 2.o liter d-jet system specialy when tuned (MPS adjusted) the 1.7 i to 2050 s going to be a near a 20% displacment increase and hence will require more modifications IF it is to work as well as a tuned 2.0 D-jet system. best to start this conversion withthe 2.0 system, but anything can work, just is which is easiest for you and makes mostest cents????? (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 11th July 2025 - 08:59 AM |
