> Brake pressure regulator
watsonrx13
post Mar 5 2010, 05:29 PM
Eric's ad selling the 912 rear calipers started a discussion about the brake pressure regulator. I'd like to continue that discussion. Eric mentions that he wouldn't replace the regulator with a 'T' fitting. What I would like to know is how could you test the regulator off of the car? At $300 - $400 a piece from the dealer I would like to test mine before I purchase a new one.
Also, Eric mentioned that the front calipers shouldn't be used on the rear, even with the regulator. Is there any problem installing a set of rebuilt rears on and not installing the parking brake cables?
Any thoughts and suggestions are welcomed. BTW, I'd like to keep this discussion only for the 4-lug wheels.
Also, what are the thoughts about replacing the master cylinder with the larger one how does that effect the brake biasing?
-- Rob
Eric_Shea
post Mar 6 2010, 06:20 PM
PMB Performance
Tom,
For your car (and about 90% of the others out there), stock brakes, new lines, new fluid and awesome pads should throw you through the windshield at the cones course... and deliver on the lawn at Monterey.
Word of Caution on Master Cylinders: There are Chinese 19mm Master Cylinders out there. I'm not your average import hater etc. but, there have been far too many failures with these units for me to recommend them. Only purchase ATE Master Cylinders for your car. If it's under $200.00, it's probably way jacked up in price and "not real".
I know it goes against the grain for the duct tape and zip tie crowd but, this is a place where you don't want to take a chance.
BRAVE_HELIOS
post Jul 23 2010, 11:13 AM
"Knowledge speaks, wisdom listens"
QUOTE(Eric_Shea @ Mar 6 2010, 06:20 PM) *
Tom,
How does this all apply to the addition of V8 weight and power? The instructions I have from Renegade states that I should replace the regulator with a "T" fitting, which I have done, although I have not tested it. Is there a difference/advantage with the V8? (IMG:style_emoticons/default/idea.gif) Thanks!
watsonrx13   Brake pressure regulator   Mar 5 2010, 05:29 PM
SirAndy   Stock brakes and a "T" is a bad idea tha...   Mar 5 2010, 05:36 PM
type47   ... and why would you want to mount rebuilt rear b...   Mar 5 2010, 05:41 PM
Tom_T   :idea: .... hmmmm ..... well - just a guess here -...   Mar 5 2010, 05:51 PM
watsonrx13   :idea: .... hmmmm ..... well - just a guess here ...   Mar 5 2010, 06:02 PM
Tom_T   :idea: .... hmmmm ..... well - just a guess here...   Mar 5 2010, 06:07 PM
watsonrx13   I'm not advocating replacing the pressure regu...   Mar 5 2010, 06:01 PM
McMark   The E in E-Brake stands for EMERGENCY. Emergencie...   Mar 5 2010, 07:10 PM
SirAndy   Actually, it's a PARKING brake ... :D Andy   Mar 5 2010, 07:28 PM
Tom_T   Actually, it's a PARKING brake ... :D Andy...   Mar 5 2010, 07:54 PM
ConeDodger   Actually, it's a PARKING brake ... :D Andy...   Mar 5 2010, 09:15 PM
kg6dxn   I could see replacing it with an adjustable one. ...   Mar 5 2010, 07:40 PM
Eric_Shea   I can't type all that crap again so I'll j...   Mar 5 2010, 07:44 PM
watsonrx13   Thanks Eric for the update. -- Rob   Mar 5 2010, 07:51 PM
Eric_Shea   Also... disconnecting hand brake cables would have...   Mar 5 2010, 07:54 PM
Eric_Shea   Read this...   Mar 5 2010, 07:58 PM
watsonrx13   Thanks Eric, very good description. BTW, is there...   Mar 5 2010, 08:08 PM
Tom_T   Great dissertation from the Guru of Porsche Brakes...   Mar 5 2010, 08:09 PM
campbellcj   Here is the original thread over in the classified...   Mar 5 2010, 10:48 PM
pbanders   Good stuff. FWIW, the "in car" test I wa...   Mar 5 2010, 11:00 PM
watsonrx13   So why does someone replace the pressure regulator...   Mar 6 2010, 07:23 AM
campbellcj   So why does someone replace the pressure regulato...   Mar 6 2010, 12:33 PM
McMark   If you're a racer looking for every last milli...   Mar 6 2010, 11:06 AM
Eric_Shea   :agree: That's why I always try to stay with...   Mar 6 2010, 02:52 PM
Tom_T   Eric - others? I'm basically looking for a bi...   Mar 6 2010, 03:22 PM
Eric_Shea   Tom, For your car (and about 90% of the others ou...   Mar 6 2010, 06:20 PM
Tom_T   Tom, For your car (and about 90% of the others o...   Mar 6 2010, 07:07 PM
BRAVE_HELIOS   Tom, For your car (and about 90% of the others o...   Jul 23 2010, 11:13 AM
campbellcj   How does this all apply to the addition of V8 wei...   Jul 23 2010, 12:32 PM
BRAVE_HELIOS   How does this all apply to the addition of V8 we...   Jul 23 2010, 12:50 PM
Tom_T   [quote name='Eric_Shea' post='1283326' date='Mar ...   Jul 23 2010, 12:43 PM
Phoenix 914-6GT   Because they simply may not understand what it rea...   Jul 23 2010, 05:13 PM
wobbletop   For a V8 I would start with the regulator in place...   Jul 23 2010, 08:23 PM
Eric_Shea   If I were Scott or Steve I'd remove that imm...   Jul 25 2010, 08:37 PM
BRAVE_HELIOS   So, I sent Renagade Hybrids an email concerning th...   Jul 26 2010, 08:21 PM
- Lo-Fi Version Time is now: 12th August 2026 - 04:37 AM
