External Oil Cooler, let me see some pictures |
tradisrad |
Jun 22 2010, 11:03 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I am going to install my 25 row Earls oil cooler over the 4th of july and I am looking for some more ideas, tip and tricks.
I plan on using a wafer adapter to keep my filter in the stock location. I will also install a thermostat and a fan. I will most likely mount it under the rear trunk. I'd like to see some pictures of what others have done. Experinces on the wafer adapter vs relocating the oil filter and what thermostats are being used. I've seen the Pelican Article. thanks -Rob |
VaccaRabite |
Jul 25 2010, 06:43 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Yes, I felt I needed the fans. I was told by a lot of folks (on World and locally) that I would not get enough airflow w/o fans. The fans keep the air moving through the cooler, and it works very well.
Is a 12inch by 6 inch unit. With the fans and the mounting brackets, its 12" long, 7" tall and 6" deep. I am not sure that I needed the brackets with how I mounted it, but the bracket kit came with rubber isolators to I used them. Zach |
Lo-Fi Version | Time is now: 6th June 2024 - 08:37 PM |
