| John Kelly |
Mar 15 2004, 09:33 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 692 Joined: 1-May 03 From: Moclips WA. Member No.: 640 |
I've done a quicky welding comparison between gas and mig for those interested:
http://allshops.org/cgi-bin/community/comm...d=9980156295554 John www.ghiaspecialties.com |
| lapuwali |
Mar 15 2004, 12:11 PM
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
It's something of a horses for courses issue. If you're doing structural welds that won't be seen (longs or footwells, for example), then MIG is easy and quick, and doesn't cause as much distortion. If you're doing welds on a visible body panel (a patch panel on a fender, for example), then gas will produce a softer weld bead that's much easier to work with hand tools. MIG weld beads tend to be hard and relatively brittle, and require grinding rather than hammering or filing to shape.
Gas setups have the advantage of being cheap and versatile. You can heat things for bending, or removing stubborn, rusty fasteners, with a gas torch, as well as weld with it. You can only weld with a MIG torch. The flip side is you can learn how to use a MIG torch to produce useful (if not pretty) welds in an afternoon, where gas welding takes much longer to master. |
John Kelly OT welding comparison Mar 15 2004, 09:33 AM
East coaster How'bout TIG? I've used TIG for my butt we... Mar 15 2004, 09:56 AM
Bleyseng Nice post, I use MIG cuz I gave away my gas rig a ... Mar 15 2004, 10:10 AM
Zaney Geoff,
What would be the best option for a newbie ... Mar 15 2004, 11:17 AM
John Kelly Hi Eastcoaster,
Nothing wrong with tig. I just d... Mar 15 2004, 11:41 AM
Zaney Thanks!
What are some decent Mig Welding set u... Mar 15 2004, 01:15 PM
tdgray Nate,
I am the ultimate amatuer welder... so I we... Mar 15 2004, 03:28 PM
Andyrew And to think, my first welds where with an arch.. ... Mar 15 2004, 06:24 PM
bongo monkey A bit confused... That is gas welding (oxyactelene... Mar 15 2004, 06:40 PM
rick 918-S I miss my oxyactelene setup. I can gas weld like c... Mar 15 2004, 11:02 PM
John Kelly The mig weld is with a shielding gas... 75/25 I d... Mar 16 2004, 10:14 AM
Gint Thanks for the info John! :beer1: Bookmark... Mar 16 2004, 10:23 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:33 PM |
