| Geezer914 |
Jul 26 2010, 10:31 AM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,288 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
Removed the steering wheel and turn signal/wiper switch. How do I get the lock cylinder out tho replace the ignition switch. This is on a 1975 914. Thanks.
| charliew |
Jul 26 2010, 03:56 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
From what I remember there is more to it than that. The turn signals and the wiper washer needs to be unhooked and all of the stuff needs to be kept together as the switches come out. Don't try to pull the turn signal stuff up without unplugging the connectors or it will come apart and you won't like that outcome. It sounds like you have already got past the turn signal sw though. Seems like there is a how to on pelican or here.
Geezer914 Ignition switch replacement on a 1975 914? Jul 26 2010, 10:31 AM
Kirmizi You need to remove the upper column to access it, ... Jul 26 2010, 11:50 AM
Geezer914 Thanks for the help. Jul 26 2010, 02:32 PM
pilothyer Just go here....pictures, instructions, all you co... Jul 26 2010, 06:35 PM
broomhandle Hello, old thread dig up. Is this the same process... Jul 25 2022, 01:57 PM
GregAmy Halfway down
http://www.914world.com/specs/rekey.... Jul 25 2022, 02:15 PM
broomhandle
Halfway down
http://www.914world.com/specs/rekey... Jul 25 2022, 04:36 PM
TheCabinetmaker You can remove the steering lock from the column a... Jul 25 2022, 05:02 PM
TheCabinetmaker There are after market replacements, but they will... Jul 25 2022, 05:04 PM
broomhandle
There are after market replacements, but they wil... Jul 26 2022, 09:52 AM
DRPHIL914
There are after market replacements, but they wi... Apr 14 2023, 07:49 AM
dr914@autoatlanta.com look in your "Tech Tips 700" there is th... Apr 14 2023, 08:33 AM
76-914
look in your "Tech Tips 700" there is t... Apr 17 2023, 06:31 PM
jim_hoyland I went to a left side switch that a member here so... Apr 14 2023, 08:34 AM
DRPHIL914 i bought 3 new ignition switches.
1- Bilistein, i... Apr 17 2023, 10:22 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd May 2026 - 03:15 AM |
