tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
ok, the dash on my old car is 10X better than the new one... I'm about to sell the old car, but am going to remove a couple of these interior items first...
first the dash... the soft part (pass. side, near windshied) is what I really need to replace... but I can't figure out how to get this part(or the hard part) off... I removed the lower dash(knee pad) thinking that it would give access.. but it did not help... also, I saw there are 2 holes: one at either end, concealed by the door when closed... are there supposed to be screws in these? if so, what kind? they appear to be completely empty... the other piece I am having trouble with is the passenger seat... the driver's seat came out just like Haynes said it would... the Passenger seat will slide all the way forward, but not pop out... (IMG:style_emoticons/default/blink.gif) last part, removing the back pad... I have removed all of the screws and the engine release knob... but the plastic piece behind the knob seems to have become a permanant part of both the backpad and the cable... it won't budge.... what's the secret to getting this off? a pic showing the dash part I need to get to: Attached image(s) ![]() |
tod914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 ![]() |
Back bolster ...
before u take it out, you will need to remove the black metal plate over the hand brake cable. Also, pull out from the bottom, then pull down. If u pull straight out you will bend or break the clips. |
Lo-Fi Version | Time is now: 17th June 2024 - 01:30 AM |
