| peteyd |
Jul 30 2010, 09:14 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 744 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
Restoration Design needs your help to determine what 914 part to make next. I listed three here, but if you have any other ideas as to what part would be a good addition let us know.
| Tom_T |
Jul 30 2010, 03:31 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
Of those 3, IMHO the front trunk floor is the most often needed, esp. for AC removal retrofits. Here are a couple of other ideas for more needed parts & the reasons why needed - 1. 70-74 Front Wall body Panel (behind bumper) - often damaged in F-end accidents & rust at bumper/foglight/horn attachments > the front wall brace(s) inside the trunk would be nice too, either separately or pre-welded to the F-wall. 2. L & R Headlight Buckets & drain tube (70-74 w/ knock-outs for 75-76) - rust damage 3. Replacement F Trunk Seal channels (curved & straight & angels0 - often rusted by trunk seal holding moisture & rusting thru 4. 70-74 Rear Wall body Panel (behind bumper & betw taillights) - often damaged in R-end accidents & rust for leaky taillight seals 5. Underbody pan sections at L & R Front Suspension Cross-member Struts/Braces Attachments (R most common) - rust due to water & windshield washer fluid leakage into bottom of fuel tank compartment, & critical suspension area stress 6. Steering Rack Cover Panels - rust & road debris damage 7. 72-76 Full Engine/Cockpit Firewall Panel with F Engine Shelf & Heat/Sound Pad & Wiring Harness Clips - heat/sound pads hold moisture against firewall/shelf & cause rust damage on later 914s (70-71 had no pads IIRC). 8. Full Hell Hole Replacement Kit &/or Pre-Assy. (Long, Inneer Wheel House, Susp. Console, Motor Mount, Engine Shelf, Battery Tray/Support, etc.) - RUST! 9. Engine Tin Sets - rust damage, road hazard losws, lazy mechanics & DAPO's not putting them back on, etc. I'm sure others can add some to their wish list! (IMG:style_emoticons/default/biggrin.gif) I say above mostly 70-74 models - not as a slam against 75-76 914s - but because there were far more 914s built & therefore surviving in the first 4 years of production, plus I have a 73 & am most familiar with issues that MY & similar MYs. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) |
| nsr-jamie |
Jul 31 2010, 08:34 AM
914 guy in Japan ![]() ![]() ![]() Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
(IMG:style_emoticons/default/agree.gif) Of those 3, IMHO the front trunk floor is the most often needed, esp. for AC removal retrofits. Here are a couple of other ideas for more needed parts & the reasons why needed - 1. 70-74 Front Wall body Panel (behind bumper) - often damaged in F-end accidents & rust at bumper/foglight/horn attachments > the front wall brace(s) inside the trunk would be nice too, either separately or pre-welded to the F-wall. 2. L & R Headlight Buckets & drain tube (70-74 w/ knock-outs for 75-76) - rust damage 3. Replacement F Trunk Seal channels (curved & straight & angels0 - often rusted by trunk seal holding moisture & rusting thru 4. 70-74 Rear Wall body Panel (behind bumper & betw taillights) - often damaged in R-end accidents & rust for leaky taillight seals 5. Underbody pan sections at L & R Front Suspension Cross-member Struts/Braces Attachments (R most common) - rust due to water & windshield washer fluid leakage into bottom of fuel tank compartment, & critical suspension area stress 6. Steering Rack Cover Panels - rust & road debris damage 7. 72-76 Full Engine/Cockpit Firewall Panel with F Engine Shelf & Heat/Sound Pad & Wiring Harness Clips - heat/sound pads hold moisture against firewall/shelf & cause rust damage on later 914s (70-71 had no pads IIRC). 8. Full Hell Hole Replacement Kit &/or Pre-Assy. (Long, Inneer Wheel House, Susp. Console, Motor Mount, Engine Shelf, Battery Tray/Support, etc.) - RUST! 9. Engine Tin Sets - rust damage, road hazard losws, lazy mechanics & DAPO's not putting them back on, etc. I'm sure others can add some to their wish list! (IMG:style_emoticons/default/biggrin.gif) I say above mostly 70-74 models - not as a slam against 75-76 914s - but because there were far more 914s built & therefore surviving in the first 4 years of production, plus I have a 73 & am most familiar with issues that MY & similar MYs. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) Yes, I need the first 3 on this list and also my longitudals are very bad on the inside of the car when I pulled my carpets out....it would be nice to see some new parts come out that are not available from AA |
peteyd Restoration panels Jul 30 2010, 09:14 AM
Todd Enlund I don't think that anyone makes a right engine... Jul 30 2010, 10:19 AM
underthetire I say a whole new tub. That way I don't have t... Jul 30 2010, 10:51 AM
N_Jay
I say a whole new tub. That way I don't have ... Feb 22 2017, 10:58 AM
SirAndy Front trunk floor
It would be great to have that... Jul 30 2010, 12:03 PM
watsonrx13
Front trunk floor
It would be great to have tha... Jul 30 2010, 03:03 PM
SirAndy Another part that is rusted out on almost every 91... Jul 30 2010, 12:08 PM
914forme
Another part that is rusted out on almost every 9... Feb 6 2017, 10:53 AM
abayer1969 :agree:
:agree:
Of those 3, IMHO the front trun... Jul 31 2010, 04:59 AM
Jacob
:agree:
:agree:
Of those 3, IMHO the front tru... Jul 31 2010, 05:46 AM
NC_Colfax
[quote name='abayer1969' post='1350448' date='Jul... Sep 2 2010, 06:47 PM
dr914@autoatlanta.com Here is what is available after each listing:
Of ... Jul 31 2010, 11:39 AM
cary Front cross panel for concours . Or the top portio... Jul 30 2010, 10:53 PM
9146986 For what it's worth Pete, I got four NOS inner... Jul 31 2010, 06:22 AM
Gint Front trunk floor is the most needed piece of what... Jul 31 2010, 07:26 AM
rick 918-S
Front trunk floor is the most needed piece of wha... Jul 31 2010, 08:19 AM
rick 918-S The lower inner wheel house rear section is a comp... Jul 31 2010, 08:37 AM
charliew Personally it's probably just me but I would b... Jul 31 2010, 11:48 AM
kwales Here's my 2 cents....
On my good car that had... Jul 31 2010, 12:10 PM
Drums66 ..Complete rear trunk floor?(I :confused: think)
... Jul 31 2010, 12:42 PM
mepstein Replacement panels that weld themselves - No offen... Jul 31 2010, 01:33 PM
scotty b
Replacement panels that weld themselves - No offe... Jul 31 2010, 06:40 PM
charliew I would think the u shaped piece could be a piece ... Jul 31 2010, 01:55 PM
kwales Charlie,
The bitch with the fender "U" ... Jul 31 2010, 04:54 PM
peteyd Thank you all for the input. There are plenty of p... Aug 2 2010, 06:15 AM
dr914@autoatlanta.com Looks like this guy is already selling the pedal c... Sep 1 2010, 01:39 PM
ripper911
Looks like this guy is already selling the pedal ... Sep 1 2010, 03:13 PM
MrKona One more vote for the 1970-74 front panel.. Aug 2 2010, 02:28 PM
1968Cayman Thanks for reminding me I haven't fixed the fr... Aug 2 2010, 09:17 PM
charliew I don't need the u channel but if I did I woul... Aug 10 2010, 04:54 PM
avidfanjpl Scotty
I just bought left/right steel rockers fro... Sep 1 2010, 11:06 AM
Root_Werks My vote is for an entire assembled 914 shell. :lo... Sep 1 2010, 11:55 AM
John I would vote for the inner and outer rear suspensi... Sep 2 2010, 10:50 PM
nathansnathan I wish you could get a piece for the 'inner in... Sep 23 2010, 09:08 AM
scotty b
I wish you could get a piece for the 'inner i... Sep 23 2010, 05:47 PM
nathansnathan B)-->
rdauenhauer resurrection. :)
So the F. trunk floor piece has... Feb 6 2017, 09:04 AM
altitude411 This for the early cars. :pray1: :pray1: :pray1:... Feb 6 2017, 11:21 AM
Mark Henry
This for the early cars. :pray1: :pray1: :pray1... Feb 6 2017, 12:44 PM
JFG My suggestion is the rear panel from trunk close t... Feb 6 2017, 11:54 AM
Luke M I have one for the wish list... Maybe Pete will ma... Feb 6 2017, 05:03 PM
Mark Henry
I have one for the wish list... Maybe Pete will m... Feb 6 2017, 05:33 PM
Luke M
I have one for the wish list... Maybe Pete will ... Feb 7 2017, 10:31 AM
peteyd
[quote name='Mark Henry' post='2452067' date='Feb... Feb 7 2017, 10:42 AM
Luke M
[quote name='Mark Henry' post='2452067' date='Fe... Feb 7 2017, 10:47 AM
bretth I second the rear panel between the taillights at ... Feb 6 2017, 05:11 PM
peteyd Gentlemen,
I have some good news. I have complete... Feb 6 2017, 08:44 PM
Steve
Ps. I know you guy always joke about bodies in w... Feb 6 2017, 11:08 PM
peteyd
Ps. I know you guy always joke about bodies in ... Feb 7 2017, 07:15 AM
[quote name='Steve' post='2452198' date='Feb 6 20... Feb 7 2017, 07:27 AM
JoeDees
Also working on the rear trailing arm mount(the ... Feb 7 2017, 09:45 AM
altitude411 :Qarl: Whoo hooo! sounds like you've been... Feb 6 2017, 08:58 PM
doug_b_928 Inner wheelhouse, lower left would be nice... Feb 6 2017, 10:01 PM
cary Keep up the GREAT work ....................... Feb 6 2017, 10:23 PM
Shadowfax
... Feb 7 2017, 10:45 AM
rdauenhauer
Gentlemen, The front latch panel, I have plans fo... Feb 7 2017, 08:28 AM
Mark Henry For a body in white VIN swapping I wouldn't ha... Feb 7 2017, 09:58 AM
peteyd I appreciate all the well wishes. Thanks for under... Feb 7 2017, 10:40 AM
Mark Henry Pete that front panel I would like the L/R corners... Feb 7 2017, 11:50 AM
914_teener Pete.....
Maybe this has been brought up before.
... Feb 8 2017, 08:34 PM
Tbrown4x4 I second the HE shells. I have two rusted sets and... Feb 9 2017, 05:56 AM
peteyd
I second the HE shells. I have two rusted sets an... Feb 22 2017, 10:51 AM
mepstein A tub made of stainless steel. I'll get Ben to... Feb 22 2017, 12:57 PM
SirAndy A tub made of stainless steel
Looks heavy ...
:ro... Feb 22 2017, 01:21 PM
Mark Henry
Looks heavy ...
:r... Feb 22 2017, 03:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2026 - 02:57 AM |
