| peteyd |
Jul 30 2010, 09:14 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 744 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
Restoration Design needs your help to determine what 914 part to make next. I listed three here, but if you have any other ideas as to what part would be a good addition let us know.
| Tom_T |
Jul 30 2010, 03:31 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
Of those 3, IMHO the front trunk floor is the most often needed, esp. for AC removal retrofits. Here are a couple of other ideas for more needed parts & the reasons why needed - 1. 70-74 Front Wall body Panel (behind bumper) - often damaged in F-end accidents & rust at bumper/foglight/horn attachments > the front wall brace(s) inside the trunk would be nice too, either separately or pre-welded to the F-wall. 2. L & R Headlight Buckets & drain tube (70-74 w/ knock-outs for 75-76) - rust damage 3. Replacement F Trunk Seal channels (curved & straight & angels0 - often rusted by trunk seal holding moisture & rusting thru 4. 70-74 Rear Wall body Panel (behind bumper & betw taillights) - often damaged in R-end accidents & rust for leaky taillight seals 5. Underbody pan sections at L & R Front Suspension Cross-member Struts/Braces Attachments (R most common) - rust due to water & windshield washer fluid leakage into bottom of fuel tank compartment, & critical suspension area stress 6. Steering Rack Cover Panels - rust & road debris damage 7. 72-76 Full Engine/Cockpit Firewall Panel with F Engine Shelf & Heat/Sound Pad & Wiring Harness Clips - heat/sound pads hold moisture against firewall/shelf & cause rust damage on later 914s (70-71 had no pads IIRC). 8. Full Hell Hole Replacement Kit &/or Pre-Assy. (Long, Inneer Wheel House, Susp. Console, Motor Mount, Engine Shelf, Battery Tray/Support, etc.) - RUST! 9. Engine Tin Sets - rust damage, road hazard losws, lazy mechanics & DAPO's not putting them back on, etc. I'm sure others can add some to their wish list! (IMG:style_emoticons/default/biggrin.gif) I say above mostly 70-74 models - not as a slam against 75-76 914s - but because there were far more 914s built & therefore surviving in the first 4 years of production, plus I have a 73 & am most familiar with issues that MY & similar MYs. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) |
| dr914@autoatlanta.com |
Jul 31 2010, 11:39 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,240 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Here is what is available after each listing:
Of those 3, IMHO the front trunk floor is the most often needed, esp. for AC removal retrofits. I agree that this part is needed. However most are bad because of the ac cutout, but most just reinstall the air conditioning. The front transverse link mounts although discontinued by the factory, are easily and readily available used and rust free - 1. 70-74 Front Wall body Panel (behind bumper) I agree with this one. Although the factory new front panels are readily avaialble, they are different than the 73-74 style and by installing the superseded panel, ones car is changed forever. They also rust away. Make this one! > the front wall brace(s) inside the trunk would be nice too, either separately or pre-welded to the F-wall. one side is still available but most times these are NOT rusted and can be cut out of a donor 2. L & R Headlight Buckets & drain tube (70-74 w/ knock-outs for 75-76) - rust damage Headlight buckets would be a good one. These do rust out and new ones are no longer available and the new ones that WERE available are shorter than the 70-74 style so that they could accommodate the 75 76 bumper shocks 3. Replacement F Trunk Seal channels (curved & straight & angels0 - often rusted by trunk seal holding moisture & rusting thru These are actually made by us and are readily available 4. 70-74 Rear Wall body Panel (behind bumper & betw taillights) - often damaged in R-end accidents & rust for leaky taillight seals These are still readily available 5. Underbody pan sections at L & R Front Suspension Cross-member Struts/Braces Attachments (R most common) - rust due to water & windshield washer fluid leakage into bottom of fuel tank compartment, & critical suspension area stress These brackets are readily available, in fact I bet we have over 100 NOS on the parts shelf 6. Steering Rack Cover Panels - rust & road debris damage These too are readily available rust free used and new 7. 72-76 Full Engine/Cockpit Firewall Panel with F Engine Shelf & Heat/Sound Pad & Wiring Harness Clips - heat/sound pads hold moisture against firewall/shelf & cause rust damage on later 914s (70-71 had no pads IIRC). Rear walls are readily available complete (I bet we have at least 20 NOS upstairs, and we already make the patch panels left and right inner and outer where these rust the most. We also have rust free back walls that can be sectioned and used to repair other rusted ones 8. Full Hell Hole Replacement Kit &/or Pre-Assy. (Long, Inneer Wheel House, Susp. Console, Motor Mount, Engine Shelf, Battery Tray/Support, etc.) - RUST! You may have seen the old thread where we welded together all of the parts we make for this area: Was a fun picture, looked like the right rear half of a real 914! All readily available but really cannot be sectioned in as one!!! 9. Engine Tin Sets - rust damage, road hazard losws, lazy mechanics & DAPO's not putting them back on, etc. Plenty of this stuff available totally rust free and nice, even the right 2.0 cylinder cover! |
peteyd Restoration panels Jul 30 2010, 09:14 AM
Todd Enlund I don't think that anyone makes a right engine... Jul 30 2010, 10:19 AM
underthetire I say a whole new tub. That way I don't have t... Jul 30 2010, 10:51 AM
N_Jay
I say a whole new tub. That way I don't have ... Feb 22 2017, 10:58 AM
SirAndy Front trunk floor
It would be great to have that... Jul 30 2010, 12:03 PM
watsonrx13
Front trunk floor
It would be great to have tha... Jul 30 2010, 03:03 PM
SirAndy Another part that is rusted out on almost every 91... Jul 30 2010, 12:08 PM
914forme
Another part that is rusted out on almost every 9... Feb 6 2017, 10:53 AM
abayer1969 :agree:
:agree:
Of those 3, IMHO the front trun... Jul 31 2010, 04:59 AM
Jacob
:agree:
:agree:
Of those 3, IMHO the front tru... Jul 31 2010, 05:46 AM
NC_Colfax
[quote name='abayer1969' post='1350448' date='Jul... Sep 2 2010, 06:47 PM
nsr-jamie
:agree:
Of those 3, IMHO the front trunk floor ... Jul 31 2010, 08:34 AM
cary Front cross panel for concours . Or the top portio... Jul 30 2010, 10:53 PM
9146986 For what it's worth Pete, I got four NOS inner... Jul 31 2010, 06:22 AM
Gint Front trunk floor is the most needed piece of what... Jul 31 2010, 07:26 AM
rick 918-S
Front trunk floor is the most needed piece of wha... Jul 31 2010, 08:19 AM
rick 918-S The lower inner wheel house rear section is a comp... Jul 31 2010, 08:37 AM
charliew Personally it's probably just me but I would b... Jul 31 2010, 11:48 AM
kwales Here's my 2 cents....
On my good car that had... Jul 31 2010, 12:10 PM
Drums66 ..Complete rear trunk floor?(I :confused: think)
... Jul 31 2010, 12:42 PM
mepstein Replacement panels that weld themselves - No offen... Jul 31 2010, 01:33 PM
scotty b
Replacement panels that weld themselves - No offe... Jul 31 2010, 06:40 PM
charliew I would think the u shaped piece could be a piece ... Jul 31 2010, 01:55 PM
kwales Charlie,
The bitch with the fender "U" ... Jul 31 2010, 04:54 PM
peteyd Thank you all for the input. There are plenty of p... Aug 2 2010, 06:15 AM
dr914@autoatlanta.com Looks like this guy is already selling the pedal c... Sep 1 2010, 01:39 PM
ripper911
Looks like this guy is already selling the pedal ... Sep 1 2010, 03:13 PM
MrKona One more vote for the 1970-74 front panel.. Aug 2 2010, 02:28 PM
1968Cayman Thanks for reminding me I haven't fixed the fr... Aug 2 2010, 09:17 PM
charliew I don't need the u channel but if I did I woul... Aug 10 2010, 04:54 PM
avidfanjpl Scotty
I just bought left/right steel rockers fro... Sep 1 2010, 11:06 AM
Root_Werks My vote is for an entire assembled 914 shell. :lo... Sep 1 2010, 11:55 AM
John I would vote for the inner and outer rear suspensi... Sep 2 2010, 10:50 PM
nathansnathan I wish you could get a piece for the 'inner in... Sep 23 2010, 09:08 AM
scotty b
I wish you could get a piece for the 'inner i... Sep 23 2010, 05:47 PM
nathansnathan B)-->
rdauenhauer resurrection. :)
So the F. trunk floor piece has... Feb 6 2017, 09:04 AM
altitude411 This for the early cars. :pray1: :pray1: :pray1:... Feb 6 2017, 11:21 AM
Mark Henry
This for the early cars. :pray1: :pray1: :pray1... Feb 6 2017, 12:44 PM
JFG My suggestion is the rear panel from trunk close t... Feb 6 2017, 11:54 AM
Luke M I have one for the wish list... Maybe Pete will ma... Feb 6 2017, 05:03 PM
Mark Henry
I have one for the wish list... Maybe Pete will m... Feb 6 2017, 05:33 PM
Luke M
I have one for the wish list... Maybe Pete will ... Feb 7 2017, 10:31 AM
peteyd
[quote name='Mark Henry' post='2452067' date='Feb... Feb 7 2017, 10:42 AM
Luke M
[quote name='Mark Henry' post='2452067' date='Fe... Feb 7 2017, 10:47 AM
bretth I second the rear panel between the taillights at ... Feb 6 2017, 05:11 PM
peteyd Gentlemen,
I have some good news. I have complete... Feb 6 2017, 08:44 PM
Steve
Ps. I know you guy always joke about bodies in w... Feb 6 2017, 11:08 PM
peteyd
Ps. I know you guy always joke about bodies in ... Feb 7 2017, 07:15 AM
[quote name='Steve' post='2452198' date='Feb 6 20... Feb 7 2017, 07:27 AM
JoeDees
Also working on the rear trailing arm mount(the ... Feb 7 2017, 09:45 AM
altitude411 :Qarl: Whoo hooo! sounds like you've been... Feb 6 2017, 08:58 PM
doug_b_928 Inner wheelhouse, lower left would be nice... Feb 6 2017, 10:01 PM
cary Keep up the GREAT work ....................... Feb 6 2017, 10:23 PM
Shadowfax
... Feb 7 2017, 10:45 AM
rdauenhauer
Gentlemen, The front latch panel, I have plans fo... Feb 7 2017, 08:28 AM
Mark Henry For a body in white VIN swapping I wouldn't ha... Feb 7 2017, 09:58 AM
peteyd I appreciate all the well wishes. Thanks for under... Feb 7 2017, 10:40 AM
Mark Henry Pete that front panel I would like the L/R corners... Feb 7 2017, 11:50 AM
914_teener Pete.....
Maybe this has been brought up before.
... Feb 8 2017, 08:34 PM
Tbrown4x4 I second the HE shells. I have two rusted sets and... Feb 9 2017, 05:56 AM
peteyd
I second the HE shells. I have two rusted sets an... Feb 22 2017, 10:51 AM
mepstein A tub made of stainless steel. I'll get Ben to... Feb 22 2017, 12:57 PM
SirAndy A tub made of stainless steel
Looks heavy ...
:ro... Feb 22 2017, 01:21 PM
Mark Henry
Looks heavy ...
:r... Feb 22 2017, 03:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th June 2026 - 02:52 AM |
