> '71 911T strut assembly, "early" or "late" ?
qa1142
post Jul 31 2010, 04:40 PM
Whiplash
So as I look at 5 lug parts... Would a '71 911T strut bold directly into my '74?
My ball joints are new, do I have to replace them with something different?
What year do 911T move from "early" to "late" style struts?
Any guess on Boge, Koni, or Bils based on this picture. obviously needs 100% rebuild
Thanks
Will
Krieger
post Jul 31 2010, 05:46 PM
Only the studs will need to be pressed out and replaced with standard 45mm ones. Someone would buy the longer ones from you. You can run as is if you have the open top steel lug nuts. The studs will stick out though. Lugs about $1 each, probably the same for used 45mm studs The shocks are probably Boge. I wouldn't pay more than $300 max for the complete struts. Depending on what you are doing the 911 A-arms have different torsion bars than the 4 cylinder cars, which means more plentifull options for replacements.
qa1142   '71 911T strut assembly   Jul 31 2010, 04:40 PM
qa1142   calipers - think I can rebuild these or would they...   Jul 31 2010, 04:46 PM
davep   That is a pretty nice set of S struts and calipers...   Jul 31 2010, 05:00 PM
Cap'n Krusty   That is a pretty nice set of S struts and caliper...   Jul 31 2010, 06:09 PM
qa1142   so this is not what I want for narrow body? These ...   Jul 31 2010, 05:06 PM
Krieger   Only the studs will need to be pressed out and rep...   Jul 31 2010, 05:46 PM
qa1142   Early S http://www.pmbperformance.com/catalog/ite...   Jul 31 2010, 06:17 PM
Cap'n Krusty   Early S http://www.pmbperformance.com/catalog/it...   Aug 1 2010, 09:18 AM
914Sixer   Buy them for the cheapest price you can get. 911 ...   Jul 31 2010, 07:23 PM
rudedude   I parted a 1971T with the same suspension you show...   Aug 1 2010, 08:04 AM
qa1142   Ok So who has picture of the bad strut with elong...   Aug 1 2010, 09:53 AM
toon1   If you get that for $150, that would be a scr...   Aug 1 2010, 10:01 AM
qa1142   another picture, I didn't think it showed more   Aug 1 2010, 10:03 AM
qa1142   and Right   Aug 1 2010, 10:04 AM
jaxdream   Really depends on caliper bolt spacing ( 3.0...   Aug 1 2010, 11:52 AM
davep   Well, those are aluminum S calipers like I said in...   Aug 1 2010, 02:22 PM
Rav914   Yeah that's a sweet set-up. Buy it. If you d...   Aug 1 2010, 05:05 PM
Eric_Shea   Without seeing the tops of the calipers, that appe...   Aug 2 2010, 08:21 AM
qa1142   Big help thanks to all let you know what out come...   Aug 2 2010, 01:03 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:02 PM
