> 911 for 914 Brakes Question
patssle
post Aug 1 2010, 03:43 PM
I can't find an answer to this...is it at all possible to put 911 brakes onto the 914 while maintaining the 4 lugs? Or must everything be swapped out?
I like my Mahles and would prefer not to have to replace them.
And while we're on it, another brakes question. I read a couple posts where people just changed out the front brakes and left the rear original - to keep the e-brake. Any opinions on having 2 different brakes front and rear?
patssle
post Aug 2 2010, 11:54 AM
What pads did you use? How many miles on the system since the new calipers? Why would you need new hardlines (if they're not leaking they will have no affect on your pedal performance)? Did you mean softlines? What was your bedding procedure? Did you set the venting clearance properly in the rear? And finally... what are you comparing it to?
Previous owner did the pads - I haven't taken the system apart yet so not sure which ones. I did some adjustments, but no luck. My brakes cannot be locked up, and the pedal is hard to press. I question the steel hardlines because I have read they can rust and clog up. Softlines were replaced by PO. I plan on bleeding the system to test this theory. The rebuilt brakes have probably a thousand or two miles on them.
If stock 914 brakes are more than enough for the 3.0L, then by all means I'll stick with them - once I figure out the issue. I just see people saying to upgrade them if you're adding weight and power to the car.
patssle   911 for 914 Brakes Question   Aug 1 2010, 03:43 PM
kg6dxn   BMW 320i brakes should bolt right on the front and...   Aug 1 2010, 08:18 PM
Mueller   not sure who sells them right now, but search for ...   Aug 1 2010, 09:04 PM
Bleyseng   Yes, the billet hubs adapt the 914 front hubs to a...   Aug 2 2010, 04:47 AM
patssle   My brakes were re-done (front bearings, discs, cal...   Aug 2 2010, 07:40 AM
JRust   I will be putting a Porsche 3.0L into my car. Is ...   Aug 2 2010, 08:16 AM
Bleyseng   with a 180hp six even 320 BMW calipers are too wea...   Aug 2 2010, 09:39 AM
Eric_Shea   The vented rotor hubs will allow you to bolt on a ...   Aug 2 2010, 11:29 AM
Phoenix 914-6GT   The vented rotor hubs will allow you to bolt on a...   Aug 2 2010, 11:47 AM
Bleyseng   The vented rotor hubs will allow you to bolt on a...   Aug 2 2010, 02:06 PM
patssle   Previous owner did the pads - I haven't take...   Aug 2 2010, 11:54 AM
Phoenix 914-6GT   Previous owner did the pads - I haven't tak...   Aug 2 2010, 11:57 AM
Eric_Shea   I should have answered your question. My bad. If...   Aug 2 2010, 03:02 PM
patssle   I should have answered your question. My bad. I...   Aug 2 2010, 07:35 PM
qa1142   Eric What are "Club Hubs" Who makes the...   Aug 2 2010, 08:01 PM
Eric_Shea   That really depends on the driving style. Jon i...   Aug 2 2010, 09:54 PM
Phoenix 914-6GT   Where to find this Mike Mueller or Mark :confused:...   Aug 3 2010, 11:07 AM
patssle   Thanks Eric, great info and I appreciate it! ...   Aug 3 2010, 11:23 AM
jmill   Rear Wheel and Hydraulics: Ferrari 308GT Caliper...   Aug 3 2010, 11:26 AM
Eric_Shea   Street and Autocross (and most DE events) These p...   Aug 3 2010, 11:28 AM
Eric_Shea   I'd recommend you get rid of your heavy A-Ca...   Aug 3 2010, 11:40 AM
jmill   I saw your caliper weight thread when you first wr...   Aug 3 2010, 12:04 PM
Eric_Shea   A pair just sold in the classified here for ...   Aug 3 2010, 12:10 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:48 PM
