| patssle |
Aug 1 2010, 03:43 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I can't find an answer to this...is it at all possible to put 911 brakes onto the 914 while maintaining the 4 lugs? Or must everything be swapped out?
I like my Mahles and would prefer not to have to replace them. And while we're on it, another brakes question. I read a couple posts where people just changed out the front brakes and left the rear original - to keep the e-brake. Any opinions on having 2 different brakes front and rear? |
| patssle |
Aug 2 2010, 11:54 AM
QUOTE What pads did you use? How many miles on the system since the new calipers? Why would you need new hardlines (if they're not leaking they will have no affect on your pedal performance)? Did you mean softlines? What was your bedding procedure? Did you set the venting clearance properly in the rear? And finally... what are you comparing it to? Previous owner did the pads - I haven't taken the system apart yet so not sure which ones. I did some adjustments, but no luck. My brakes cannot be locked up, and the pedal is hard to press. I question the steel hardlines because I have read they can rust and clog up. Softlines were replaced by PO. I plan on bleeding the system to test this theory. The rebuilt brakes have probably a thousand or two miles on them. If stock 914 brakes are more than enough for the 3.0L, then by all means I'll stick with them - once I figure out the issue. I just see people saying to upgrade them if you're adding weight and power to the car. |
| PeeGreen 914 |
Aug 2 2010, 11:57 AM
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest
QUOTE What pads did you use? How many miles on the system since the new calipers? Why would you need new hardlines (if they're not leaking they will have no affect on your pedal performance)? Did you mean softlines? What was your bedding procedure? Did you set the venting clearance properly in the rear? And finally... what are you comparing it to? Previous owner did the pads - I haven't taken the system apart yet so not sure which ones. I did some adjustments, but no luck. My brakes cannot be locked up. I question the steel hardlines because I have read they can rust and clog up. Softlines were replaced by PO. I plan on bleeding the system to test this theory. The rebuilt brakes have probably a thousand or two miles on them. If stock 914 brakes are more than enough for the 3.0L, then by all means I'll stick with them - once I figure out the issue. I just see people saying to upgrade them if you're adding weight and power to the car. If you can't lock them up something is not right. |
patssle 911 for 914 Brakes Question Aug 1 2010, 03:43 PM
kg6dxn BMW 320i brakes should bolt right on the front and... Aug 1 2010, 08:18 PM
Mueller not sure who sells them right now, but search for ... Aug 1 2010, 09:04 PM
Bleyseng Yes, the billet hubs adapt the 914 front hubs to a... Aug 2 2010, 04:47 AM
patssle My brakes were re-done (front bearings, discs, cal... Aug 2 2010, 07:40 AM
JRust
I will be putting a Porsche 3.0L into my car. Is ... Aug 2 2010, 08:16 AM
Bleyseng with a 180hp six even 320 BMW calipers are too wea... Aug 2 2010, 09:39 AM
Eric_Shea The vented rotor hubs will allow you to bolt on a ... Aug 2 2010, 11:29 AM
Phoenix 914-6GT
The vented rotor hubs will allow you to bolt on a... Aug 2 2010, 11:47 AM
Bleyseng
The vented rotor hubs will allow you to bolt on a... Aug 2 2010, 02:06 PM
Eric_Shea I should have answered your question. My bad.
If... Aug 2 2010, 03:02 PM
patssle
I... Aug 2 2010, 07:35 PM
qa1142 Eric
What are "Club Hubs" Who makes the... Aug 2 2010, 08:01 PM
Eric_Shea
That really depends on the driving style. Jon i... Aug 2 2010, 09:54 PM
Phoenix 914-6GT Where to find this Mike Mueller or Mark :confused:... Aug 3 2010, 11:07 AM
patssle Thanks Eric, great info and I appreciate it!
... Aug 3 2010, 11:23 AM
jmill
Rear Wheel and Hydraulics: Ferrari 308GT Caliper... Aug 3 2010, 11:26 AM
Eric_Shea Street and Autocross (and most DE events) These p... Aug 3 2010, 11:28 AM
Eric_Shea
I'd recommend you get rid of your heavy A-Ca... Aug 3 2010, 11:40 AM
jmill I saw your caliper weight thread when you first wr... Aug 3 2010, 12:04 PM
Eric_Shea A pair just sold in the classified here for ... Aug 3 2010, 12:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:13 PM |
