What tires will fit on these wheels, tire size question |
brandomc |
Aug 3 2010, 12:31 PM
Member Group: Members Posts: 113 Joined: 14-May 09 From: los angeles california Member No.: 10,363 Region Association: Southern California |
Hi, i have read some other posts saying that i can replace my 165 15 tires with 195 65 r15's. I was wondering if anyone has the same wheels as me with the 195 tire size. Mine already seem close to the wheel arch lip in the rear. But there is still enough clearance to fit my fingers between. I attatched a pic of my car. Which wheels are these? Should the 195's fit and not rub. Thanks
Brandon |
underthetire |
Aug 3 2010, 02:12 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
had 195/60's on mine. worked well.
markb |
Aug 3 2010, 02:17 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
had 195/60's on mine. worked well. (IMG:style_emoticons/default/agree.gif) That's about as wide as you can go, normally. I tried 205's on my Riv's & they rubbed. |
underthetire |
Aug 3 2010, 02:25 PM
had 195/60's on mine. worked well. (IMG:style_emoticons/default/agree.gif) That's about as wide as you can go, normally. I tried 205's on my Riv's & they rubbed. I got 205's to work in the rear, but looked kinda retardo with way too much sidewall bulge. Measure gaps on your car to see if you can fit 15mm on both sides of the tire. Pretty simple, 165=165mm width, 195=195mm width. The 60 or 70 is the aspect ratio in percentage of tire width 60 =60% of width, so, a 195 tire on a 15" rim with a 60 series will be 117mm per side. So 117+117+381mm (15")=615mm total height, or 24.21" high. |
Lo-Fi Version | Time is now: 4th June 2024 - 05:29 AM |
