> Caliper removal, Need pics or detailed instruction
stateofidleness
post Aug 8 2010, 02:17 PM
The pelican article assumes a lot. One picture and vague directions such as "remove both bolts", with no mention of their location, size, etc.
I've never messed with the brakes before so I don't know what all I'm looking at. Since the hardline nut is a perfect circle now (wow...) i had to cut it in half, now I'm trying to remove the caliper from the car (rear drivers) and don't know the order or which bolts to loosen.
I have taken the parking brake cable off, and removed the 90angle little clips, but not sure where to go from there...
can someone post some pics of the bolts the hold the halves together and maybe their size? any other trips/tricks/pitfalls to avoid will be greatly appreciated as well!
brake bleeding job has turned into a "replace every 40yr old part of the brake system" job... sigh.
had to go buy some flare wrenches too, never heard of them before this!
type47
post Aug 9 2010, 06:28 AM
Viermeister
I'd have to admit in front of the whold world that I torqued the bolts "gud-n-tight" as my torque wrench couldn't fit into the area. Waitin' for the Cap'n... (IMG:style_emoticons/default/blowup.gif)
Spoke
post Aug 9 2010, 10:23 AM
Jerry
QUOTE(type47 @ Aug 9 2010, 08:28 AM) *
I tighten small nuts and bolts with the gud-n-tight method. Too tight and you snap the bolts or cause undue stress on the nut/bolt/fitting, too loose and you have leakage. For me it's just a feel thing.
The brake fittings is just a feel. Same with the caliper bolts. Tighten enough so the bolts won't come off.
Usually I use the size of the wrench to determine how much torque I use. Small wrench = low torque, big wrench = high torque.
If engine internals, clutch, etc., I definitely use a torque wrench. Same with wheel lugs/nuts.
- Lo-Fi Version Time is now: 2nd July 2025 - 08:02 PM
