transmission leaking..., dripping from clutch fork and bell housing... |
malaga_red75 |
Aug 7 2010, 04:28 PM
'74 2.5L N/A Subie Group: Members Posts: 454 Joined: 5-March 06 From: Menlo Park, CA Member No.: 5,674 Region Association: None |
title says it. just got my car back on the road and it now has a transmission leak. dripping from the clutch fork and bell housing... let me know what you think.
-Peter |
Richard Casto |
Aug 9 2010, 06:21 AM
Blue Sky Motorsports, LLC Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
You can get a seal puller from just about anywhere (local auto parts store). It just has a handle with two hooks on the end. Just make sure you don't mess up the machined sealing surface of the case when you pull out the old seal. The seal can be bought from the usual list of Porsche parts suppliers.
When reading this thread, I also am curious to know if you have a bearing for the end of the input shaft. If you look at the end of the input shaft, you will see that there is a bit of shaft that extends beyond the splined part that fits into the clutch disk. That stub is what slides into the support bearing. |
malaga_red75 |
Aug 9 2010, 10:31 AM
When reading this thread, I also am curious to know if you have a bearing for the end of the input shaft. If you look at the end of the input shaft, you will see that there is a bit of shaft that extends beyond the splined part that fits into the clutch disk. That stub is what slides into the support bearing. So the support bearing is in the clutch assembly? ill have to check it out. |
underthetire |
Aug 9 2010, 12:25 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
When reading this thread, I also am curious to know if you have a bearing for the end of the input shaft. If you look at the end of the input shaft, you will see that there is a bit of shaft that extends beyond the splined part that fits into the clutch disk. That stub is what slides into the support bearing. So the support bearing is in the clutch assembly? ill have to check it out. It's actually in the flywheel on a T-4 |
Lo-Fi Version | Time is now: 9th June 2024 - 07:49 PM |
