> Weber IDF Main jet help
tornik550
post Aug 11 2010, 07:29 PM
I am in the process of tuning my car after a rebuild. I have dual weber 40's. My engine is a 2.27L. Everything is going pretty well. I am slowly getting the jetting closer and closer. I was driving around at about 60mph yesterday. The head were hotter than I like (325 degrees). I checked the spark plugs and they were bone white. The main jets were at 160. I increased them to 170 (above 160 I only have increments of 10). With the increase to 170, the car is running very well and the temp at around 60mph cruising is around 275. I sped home, tuned off the car and took out the plugs- bone white. I was quite surprised.
The main jet size sounds high too me. Does it sound high to everyone else? Is it possible that I am needing a high main jet size because of the float level? I have my floats set at 10.5 with the gasket.
Any opinions would be greatly appreciated
tornik550
post Aug 13 2010, 08:32 AM
I think that I need clarification of the stock float height. I have seen people say that the float should be set at 11mm from the top of the gasket. I also saw in in my haynes weber manual that you should set the floats at 10mm NOT including the gasket. I was told by someone at aircooled.net that I was to set the floats at 10.5mm (gasket or not?). I have it set at 10 mm off the top of the gasket which would be 11 mm off the metal. What is the correct float height. It seems that I should be around the correct area.
The nice thing is that I have a large amount of main jets. I have everything from about 130 to 160 in increments of 5. Above that I have increments of 10. I have AC jets of 190, 200, 210 and 200.
Also, to clarify, last night when I was driving, I had the sluggish feeling when was driving above 2000 or so rpms. Below that everything was fine.
tornik550   Weber IDF Main jet help   Aug 11 2010, 07:29 PM
Jake Raby   What size venturis? 40s are quite small for a 2270   Aug 11 2010, 08:18 PM
type2man   What size venturis? 40s are quite small for a 227...   Aug 11 2010, 08:39 PM
tomeric914   The main jets were at 160. Just for clarity, are...   Aug 11 2010, 08:53 PM
tomeric914   BTW, I have 40's on my 2270 but changed out to...   Aug 11 2010, 08:57 PM
tornik550   My idf's have 32 vents. I am definitely chang...   Aug 11 2010, 09:24 PM
ME733   My idf's have 32 vents. I am definitely chan...   Aug 12 2010, 09:10 AM
john rogers   The venturi's sound a bit too small as you sur...   Aug 11 2010, 10:27 PM
jmill   The larger vents would send a weaker signal to the...   Aug 11 2010, 10:57 PM
jmill   Another thing you might want to look at is your ET...   Aug 12 2010, 07:51 AM
tornik550   Right now I have AC jets at 220. The reason for t...   Aug 12 2010, 09:21 AM
ME733   Right now I have AC jets at 220. The reason for ...   Aug 12 2010, 10:51 AM
john rogers   The rule of thumb I learned when racing which shou...   Aug 12 2010, 11:08 AM
jmill   The AIR correction jet has a very significant cha...   Aug 12 2010, 11:10 AM
tornik550   Here is an update. I drove my car to work today. ...   Aug 12 2010, 08:25 PM
ME733   Here is an update. I drove my car to work today....   Aug 13 2010, 08:16 AM
john rogers   You will need to become the master of the trade of...   Aug 12 2010, 09:54 PM
tornik550   I think that I need clarification of the stock flo...   Aug 13 2010, 08:32 AM
ME733   .........put the float level back where it was.......   Aug 13 2010, 08:43 AM
jmill   Murray is correct in that changing multiple things...   Aug 13 2010, 09:26 AM
tornik550   Murray is correct in that changing multiple thing...   Aug 13 2010, 09:32 AM
McMark   Increasing the float height will not change the mi...   Aug 13 2010, 12:52 PM
jmill   Increasing the float height will not change the m...   Aug 13 2010, 02:01 PM
McMark   The rate at which fuel is admitted to the emulsion...   Aug 13 2010, 02:19 PM
jmill   You can't seriously be arguing that the level...   Aug 13 2010, 04:08 PM
McMark   I guess I read that paragraph a completely differe...   Aug 13 2010, 05:34 PM
john rogers   From several of the posts here I seem to read that...   Aug 13 2010, 06:22 PM
tornik550   I am new to carbs. I am a human mechanic and not ...   Aug 13 2010, 06:30 PM
ME733   I am new to carbs. I am a human mechanic and not...   Aug 14 2010, 04:48 PM
jeffdon   This is some of the most insightful carb tuning ta...   Aug 14 2010, 09:02 PM
tornik550   So what is the cheapest way to get a o2 sensor, a/...   Aug 13 2010, 06:35 PM
McMark   PLX is $269, here. Innovate Motorsports is ...   Aug 13 2010, 07:14 PM
john rogers   I would suggest that for optimizing a carb setup t...   Aug 15 2010, 11:14 AM
ME733   I would suggest that for optimizing a carb setup ...   Aug 16 2010, 07:43 AM
jmill   If your car were perfect at idle and perfect at ...   Aug 16 2010, 08:19 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:47 PM
