> Weber IDF Main jet help
tornik550
post Aug 11 2010, 07:29 PM
I am in the process of tuning my car after a rebuild. I have dual weber 40's. My engine is a 2.27L. Everything is going pretty well. I am slowly getting the jetting closer and closer. I was driving around at about 60mph yesterday. The head were hotter than I like (325 degrees). I checked the spark plugs and they were bone white. The main jets were at 160. I increased them to 170 (above 160 I only have increments of 10). With the increase to 170, the car is running very well and the temp at around 60mph cruising is around 275. I sped home, tuned off the car and took out the plugs- bone white. I was quite surprised.
The main jet size sounds high too me. Does it sound high to everyone else? Is it possible that I am needing a high main jet size because of the float level? I have my floats set at 10.5 with the gasket.
Any opinions would be greatly appreciated
tornik550
post Aug 13 2010, 06:30 PM
I am new to carbs. I am a human mechanic and not a car mechanic. I am trying to learn and I appreciate everyones help.
Last night I only made three changes. The changes were that I increased the venturi size which should have leaned the mixture. I slightly increased the fuel pressure and I raised the float level from 11mm with the gasket to 10mm with the gasket. I then had a super rich mixture.
Today, I drove around quite a bit and played with the mains. I had AC jets of 190 the entire time. I tried 180, 170 and 160 and all were rich however 160 didn't seem too bad. I didn't have a 155 with me so I tried 150 and Now the mixture is lean. I am trying to find my 155's and i think that I should be dead on.
tornik550   Weber IDF Main jet help   Aug 11 2010, 07:29 PM
Jake Raby   What size venturis? 40s are quite small for a 2270   Aug 11 2010, 08:18 PM
type2man   What size venturis? 40s are quite small for a 227...   Aug 11 2010, 08:39 PM
tomeric914   The main jets were at 160. Just for clarity, are...   Aug 11 2010, 08:53 PM
tomeric914   BTW, I have 40's on my 2270 but changed out to...   Aug 11 2010, 08:57 PM
tornik550   My idf's have 32 vents. I am definitely chang...   Aug 11 2010, 09:24 PM
ME733   My idf's have 32 vents. I am definitely chan...   Aug 12 2010, 09:10 AM
john rogers   The venturi's sound a bit too small as you sur...   Aug 11 2010, 10:27 PM
jmill   The larger vents would send a weaker signal to the...   Aug 11 2010, 10:57 PM
jmill   Another thing you might want to look at is your ET...   Aug 12 2010, 07:51 AM
tornik550   Right now I have AC jets at 220. The reason for t...   Aug 12 2010, 09:21 AM
ME733   Right now I have AC jets at 220. The reason for ...   Aug 12 2010, 10:51 AM
john rogers   The rule of thumb I learned when racing which shou...   Aug 12 2010, 11:08 AM
jmill   The AIR correction jet has a very significant cha...   Aug 12 2010, 11:10 AM
tornik550   Here is an update. I drove my car to work today. ...   Aug 12 2010, 08:25 PM
ME733   Here is an update. I drove my car to work today....   Aug 13 2010, 08:16 AM
john rogers   You will need to become the master of the trade of...   Aug 12 2010, 09:54 PM
tornik550   I think that I need clarification of the stock flo...   Aug 13 2010, 08:32 AM
ME733   .........put the float level back where it was.......   Aug 13 2010, 08:43 AM
jmill   Murray is correct in that changing multiple things...   Aug 13 2010, 09:26 AM
tornik550   Murray is correct in that changing multiple thing...   Aug 13 2010, 09:32 AM
McMark   Increasing the float height will not change the mi...   Aug 13 2010, 12:52 PM
jmill   Increasing the float height will not change the m...   Aug 13 2010, 02:01 PM
McMark   The rate at which fuel is admitted to the emulsion...   Aug 13 2010, 02:19 PM
jmill   You can't seriously be arguing that the level...   Aug 13 2010, 04:08 PM
McMark   I guess I read that paragraph a completely differe...   Aug 13 2010, 05:34 PM
john rogers   From several of the posts here I seem to read that...   Aug 13 2010, 06:22 PM
tornik550   I am new to carbs. I am a human mechanic and not ...   Aug 13 2010, 06:30 PM
ME733   I am new to carbs. I am a human mechanic and not...   Aug 14 2010, 04:48 PM
jeffdon   This is some of the most insightful carb tuning ta...   Aug 14 2010, 09:02 PM
tornik550   So what is the cheapest way to get a o2 sensor, a/...   Aug 13 2010, 06:35 PM
McMark   PLX is $269, here. Innovate Motorsports is ...   Aug 13 2010, 07:14 PM
john rogers   I would suggest that for optimizing a carb setup t...   Aug 15 2010, 11:14 AM
ME733   I would suggest that for optimizing a carb setup ...   Aug 16 2010, 07:43 AM
jmill   If your car were perfect at idle and perfect at ...   Aug 16 2010, 08:19 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:48 PM
