Rebuilding the rear brake with some “small” problems, Castle nut does not move - wtf!!! |
draganc |
Aug 14 2010, 04:28 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Hi everybody!
I’m in the progress of rebuilding my rear brakes and are having problems loosing the rear castle nut, which holds the shaft. Not really a surprise since the car was sitting for the last 8 years w/o usage. I have used W40 for several days. No result. I have torched (IMG:style_emoticons/default/welder.gif) (only with a hand/propane torch) the nut several times up to about 650F. Used a torque wrench while the nut is cold and hot. No result - after 5 hours. I’m sure someone else had a similar problem. Any tips advise? Did anyone ever cut the nut of the shaft? How did it work out? Which tool did you use? Will a Dremmel work? Thanks a lot for any advise/tips. Dragan |
underthetire |
Aug 14 2010, 04:31 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Why are you taking the nut off to do brakes?
Lo-Fi Version | Time is now: 8th June 2024 - 09:21 PM |
