engine shroud and alternator on a /6, removal in the car |
krk |
Jan 10 2004, 05:20 PM
Senior Member Group: Members Posts: 997 Joined: 27-December 02 From: San Jose Member No.: 22 |
Folks,
Today, I'm taking advantage of the weather and trying to get to the alternator in my /6 -- which is apparently dead. Anyway, i have shop manuals which, and this is unusual, are almost useless for this. The carbs and manifolds are out. All shroud bolts (that I can find) are out. The shop manual thinks I can remove the shroud -- but there are "issues". for example, there is a wiring thing that goes through roughly the center of the shroud. (hopefully there are detachable ends behind it somehow). Are there tricks at this stage that I should be aware of? I found the secret bold behind the distributor, and the other two secret bolts accessed under the car at the back. Did I miss something? Just taking a break -- almost time to go back at it. Any BTDT appreciated of course! kim. |
krk |
Mar 17 2004, 12:07 AM
Carl,
I'm not sure it's safe to pick on hamburgers on this board. You know how politically correct we are. (IMG:style_emoticons/default/laugh.gif) But there is no doubt that the car runs cooler. Even after only a week of being back in service, the temp gauge tells the story. Gum up your cooler and you will pay. I had no idea of course, so I was looking into under car flaps (prolly will still install them) and so forth, but if your cooler is plugged up, none of that will matter. kim. |
Lo-Fi Version | Time is now: 11th June 2024 - 06:37 AM |
