| RFoulds |
Aug 10 2010, 12:48 PM
914Rennsport ![]() ![]() ![]() Group: Members Posts: 870 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region
As you might have seen elsewhere on this site and others, I just bought my fourth 914, this time a well preserved 1974 Olympic Blue, that has been in storage for over 20 years.
So first, this is an open invite for anyone near La Quinta CA to come by and see it anytime you like. And second, a call out for any advice or help to put this car back to dealer showroom condition. Also, what shows I should consider entering once she is complete. One of my first dilemnas is the side stripes. Were these dealer added? or factory? Should I leave the slightly worn originals in place?, replace them with repros, or remove altogether?? Randy |
| RFoulds |
Aug 14 2010, 05:26 PM
Pulled fuel tank today. Sorry no pics, camera still not back from repair. very clean underneath, but the front two bolts for the underpan were missing. Wire was stuck in there to hold it on!
tank is half full of old gas, and all rust inside. Filler tube is rusted away inside. Under tank, one black wire ran down from above, with a quick connector right at the access hole. Any idea what that was? was fuel pump locate here at one time?? |
| Tom_T |
Aug 15 2010, 10:20 AM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
Pulled fuel tank today. Sorry no pics, camera still not back from repair. very clean underneath, but the front two bolts for the underpan were missing. Wire was stuck in there to hold it on! tank is half full of old gas, and all rust inside. Filler tube is rusted away inside. Under tank, one black wire ran down from above, with a quick connector right at the access hole. Any idea what that was? was fuel pump locate here at one time?? On pre-75 914s, the factory recommended fuel pump relocation Service Bulletin was/is to put it up behind the steering rack cover behind the ZF Rack itself next to the lower access hole. Power can be wired either along the pass. side rocker/sill space or through the tunnel - but most mechanics don't want to screw with this extra work & it's not accessible for inspection later for a wiring problem. This would require 2 wires for power the FP though, so that's either half the set or something else. |
| JeffBowlsby |
Aug 17 2010, 01:28 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,264 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
I'd like to see that service bulletin Tom...can you send it to me? Never heard that the factory recommended this relocation, but I have not come across any 914 service bulletins either. All I have are the Service and Tech manuals, and recall campaigns, I don't recall any of them ever suggesting the FP relocation.
I have also never experienced vapor lock here in NorCal, ever. Maybe it occurs in hotter climes, but not here that I personally know of. (IMG:style_emoticons/default/biggrin.gif) Pulled fuel tank today. Sorry no pics, camera still not back from repair. very clean underneath, but the front two bolts for the underpan were missing. Wire was stuck in there to hold it on! tank is half full of old gas, and all rust inside. Filler tube is rusted away inside. Under tank, one black wire ran down from above, with a quick connector right at the access hole. Any idea what that was? was fuel pump locate here at one time?? On pre-75 914s, the factory recommended fuel pump relocation Service Bulletin was/is to put it up behind the steering rack cover behind the ZF Rack itself next to the lower access hole. Power can be wired either along the pass. side rocker/sill space or through the tunnel - but most mechanics don't want to screw with this extra work & it's not accessible for inspection later for a wiring problem. This would require 2 wires for power the FP though, so that's either half the set or something else. |
| Tom_T |
Aug 17 2010, 02:51 PM
Hey Jeff,
I don't have that bulletin per se, but my longtime mechanics at Hans Imports used to have it on-hand in the "old school" paper file days - & I remember looking at it in the binder when they suggested the FP relo for vapor lock back in the late 70's (& did it then). I can ask them if they happen to still have their old VoA & P+A Service bulletins/binders to make a copy, but I'm not holding my breath cuz they've cleared out most old stuff over the 30+ years since! Also, I tried to get a set of the service bulletin binders myself on evil-bay a while back, but wasn't successful bidding for it - & don't even know how complete they were. If I do come across an actual copy again - &/or anything else similar on our 914s, then I'll certainly shoot you off some copies. You might want to link your 914 Tech Notebook section to the main 914 CANAM & Classic 914 main pages, because IIRC they don't have a link, but it's chock full of excellent info! Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// I'd like to see that service bulletin Tom...can you send it to me? Never heard that the factory recommended this relocation, but I have not come across any 914 service bulletins either. All I have are the Service and Tech manuals, and recall campaigns, I don't recall any of them ever suggesting the FP relocation. I have also never experienced vapor lock here in NorCal, ever. Maybe it occurs in hotter climes, but not here that I personally know of. (IMG:style_emoticons/default/biggrin.gif) Pulled fuel tank today. Sorry no pics, camera still not back from repair. very clean underneath, but the front two bolts for the underpan were missing. Wire was stuck in there to hold it on! tank is half full of old gas, and all rust inside. Filler tube is rusted away inside. Under tank, one black wire ran down from above, with a quick connector right at the access hole. Any idea what that was? was fuel pump locate here at one time?? On pre-75 914s, the factory recommended fuel pump relocation Service Bulletin was/is to put it up behind the steering rack cover behind the ZF Rack itself next to the lower access hole. Power can be wired either along the pass. side rocker/sill space or through the tunnel - but most mechanics don't want to screw with this extra work & it's not accessible for inspection later for a wiring problem. This would require 2 wires for power the FP though, so that's either half the set or something else. |
RFoulds Open invite and call for help. Aug 10 2010, 12:48 PM
Bleyseng Dealer accessory item applied by the dealer or you... Aug 10 2010, 04:00 PM
Pat Garvey
Dealer accessory item applied by the dealer or yo... Aug 14 2010, 06:56 PM
Tom_T
[quote name='Bleyseng' post='1354763' date='Aug 1... Aug 17 2010, 06:08 PM
Tom_T :agree:
..... well in part, since the decals ... Aug 11 2010, 01:39 AM
Tom_T Note item "D" in the Porsche+Audi dealer... Aug 11 2010, 01:49 AM
Bleyseng Just don't add the bumper rails! :barf:
... Aug 11 2010, 03:20 AM
Krieger Well.... show us some pictures. I am too far away... Aug 11 2010, 09:20 AM
RFoulds Thanks everyone for the great info! I think I... Aug 11 2010, 11:19 AM
Tom_T Randy - don't know how soon you'd be ready... Aug 11 2010, 01:44 PM
RFoulds Wow! great info. thanks! keep it coming... Aug 11 2010, 01:54 PM
muncokiho
Wow! great info. thanks! keep it comin... Aug 11 2010, 03:04 PM
Tom_T
Wow! great info. thanks! keep it comi... Aug 11 2010, 03:59 PM
muncokiho
[quote name='muncokiho' post='1355157' date='Aug ... Aug 11 2010, 04:27 PM
Tom_T
I know the car, it is not a 2L. The steel wheels ... Aug 11 2010, 04:51 PM
RFoulds As for wheels, were the Rivieras a dealer installe... Aug 11 2010, 01:44 PM
Tom_T
As for wheels, were the Rivieras a dealer install... Aug 11 2010, 03:51 PM
Pat Garvey
As for wheels, were the Rivieras a dealer install... Aug 11 2010, 07:06 PM
tod914 Before you peel off the stripes, you might want to... Aug 11 2010, 04:52 PM
RFoulds The stripes have an inch or two missing on each si... Aug 11 2010, 05:18 PM
muncokiho
The stripes have an inch or two missing on each s... Aug 12 2010, 05:59 AM
RFoulds Wheels were not frozen. brakes and bearings movin... Aug 12 2010, 09:06 AM
RFoulds Found the tool kit last night. It was under the s... Aug 12 2010, 10:22 AM
Bleyseng isn't there a pic in the owners manual? I thou... Aug 12 2010, 02:36 PM
RFoulds Didn't think to look there! thanks! Aug 12 2010, 02:47 PM
Tom_T I'm pretty sure the towel wasn't OE Randy... Aug 12 2010, 03:55 PM
RFoulds Still not sure what the wires there are. Fuel tan... Aug 17 2010, 12:45 PM
Jeff Bowlsby Thanks Tom. I have heard rare and vague reference... Aug 17 2010, 05:49 PM
Tom_T
Thanks Tom. I have heard rare and vague referenc... Aug 17 2010, 06:03 PM
RFoulds Just an update. OE steel wheels are being sandbla... Aug 25 2010, 01:33 PM
Tom_T
Just an update. OE steel wheels are being sandbl... Aug 25 2010, 01:57 PM
RFoulds Hey Tom,
Yes, I checked the O&H wheel post an... Aug 25 2010, 02:33 PM
Tom_T
Hey Tom,
Yes, I checked the O&H wheel post a... Aug 26 2010, 12:01 AM
Pat Garvey Not that this should be an issue, but the exterior... Aug 25 2010, 07:29 PM
Niklas Hi!
Yes the colour is a european colour code ... Aug 26 2010, 02:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 04:42 AM |
