> Make my car handle better, CHEAP!!!!!!
ninefourteener
post Mar 17 2004, 09:21 AM
Perfectly Normal Guy :)
Ok..... forgive me for buying / owning a teener that pretty much underwent a ground up restoration less than 10K before I bought it......... so I really haven't done anything "mechanical" to it at all..... only appearance upgrades.
But I'd like it to handle better.. you know, hold the curves tighter, less body roll, etc.
Anyone have any ideas on what to do that isn't going to break the bank? Maybe some tips? Tricks? Cheap parts? Where can I get them? Where do I start? Whats the easiest upgrade, and will produce the highest desired effect??
Look at it from the perspective of a car that the suspension is 100% original.... as mine is. I know there are a lot of auto Xers on here, so any help you can provide will be greatly appreciated (IMG:style_emoticons/default/smile.gif)
Joe Bob
post Mar 17 2004, 10:05 AM
Add a front sway bar....it requires tank removal...good time to replace those crappy 30 year old fuel lines that nobody ever sees.
RonK has a post on the skyrat board for some 930 18mm sway bars...he's my neighbor. 15mm was stock on a 914.
If I remember....both the stock 914 and early 930 sway bars are non adjustable....under/over steer was dialed in with rear spring variation....or with higher boost in the 930 case.... (IMG:style_emoticons/default/mueba.gif)
After that, a good alignment and corner balance....
ninefourteener   Make my car handle better   Mar 17 2004, 09:21 AM
majkos   :lol: Ha-ha-ha! Cheap! :lol: Good one...   Mar 17 2004, 09:40 AM
thesey914   Has it got sway bars? what shocks does it have? No...   Mar 17 2004, 09:40 AM
Steve   If you want a good handling street car I would sta...   Mar 17 2004, 09:44 AM
agentblr   Try adding some turbo tie rods$130,about 1/2 ...   Mar 17 2004, 09:46 AM
ninefourteener   Hmmm... maybe I should have elaborated a bit.... t...   Mar 17 2004, 09:47 AM
jonwatts   Find out (or tell us if you already know) what you...   Mar 17 2004, 09:48 AM
agentblr   :beer3: :beer3: For a couple hundred I would firs...   Mar 17 2004, 09:57 AM
ninefourteener   ...   Mar 17 2004, 09:59 AM
!   Add a front sway bar....it requires tank removal.....   Mar 17 2004, 10:05 AM
jonwatts   A '72 wouldn't (or shouldn't) have swa...   Mar 17 2004, 10:06 AM
jonwatts   Oh, and I agree with Mikez (hi Mike!). Don...   Mar 17 2004, 10:15 AM
majkos   The stock front sway is fairly easy install.The ha...   Mar 17 2004, 10:21 AM
Bleyseng   :agree: Cheapest add on would be a sway bar for ...   Mar 17 2004, 10:24 AM
mskala   Tires...   Mar 17 2004, 08:26 PM
majkos   I :agree: with tires!then second "stock" swa...   Mar 17 2004, 08:37 PM
Brad Roberts   I think we should ask him a few questions: 1. Wha...   Mar 17 2004, 11:38 PM
jonwatts   I feel this thread has definite "flame war" potent...   Mar 17 2004, 11:56 PM
airsix   ...   Mar 18 2004, 02:12 AM
rhodyguy   the 4 koni's and the spring swap with adjusta...   Mar 18 2004, 06:59 AM
ninefourteener
- Lo-Fi Version Time is now: 12th November 2026 - 09:53 AM
