| j3vw |
Aug 18 2010, 09:28 AM
Newbie ![]() Group: Members Posts: 14 Joined: 18-August 10 From: columbia TN Member No.: 12,066 Region Association: None |
Hey Folks...little help?.......73 1.7...idles pefect, ignition system and valves good.....idle air fuel mix fine...over aprox 2500 rpm....leans out bad...tested press sensor, vac.. good resistance good...all indicators are full load enrichment not happening...any ideas?...I do alot of L-jet work and ECU"s are rarely the problem..
Thanks! Rich |
| Bleyseng |
Aug 18 2010, 10:47 AM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Untampered with? meaning factory unit with the epoxy seal over the WOT stop?
If all these Djet parts are stock in good condition then I'd look for a vacuum leak as the AFR should be 13.5-14 to one at 2500rpms... Check the injector seals, manifold gaskets, throttle body seal etc as air is bleeding in to mess with your AFR.. Last thing I would do is adjust the MPS but IF everything else checks out to spec then look at that. If its a rebuilt unit, go ahead and adjust it. I can write how if you need it. |
j3vw Help Need D-jet Jedi! Aug 18 2010, 09:28 AM
realred914
Hey Folks...little help?.......73 1.7...idles pef... Aug 18 2010, 09:37 AM
j3vw
Hey Folks...little help?.......73 1.7...idles pe... Aug 18 2010, 09:44 AM
Bleyseng check out the TPS and also how do you know its lea... Aug 18 2010, 10:00 AM
j3vw
check out the TPS and also how do you know its le... Aug 18 2010, 10:07 AM
Bleyseng What is the number on the MPS? Aug 18 2010, 10:15 AM
j3vw
-100 049
cyl h... Aug 18 2010, 10:27 AM
Bleyseng Untampered with? meaning factory unit with the epo... Aug 18 2010, 10:46 AM
j3vw
Untampered with? meaning factory unit with the ep... Aug 18 2010, 10:59 AM
Bleyseng and the ECU is a 037?
fuel pressure stays at 30psi... Aug 18 2010, 12:22 PM
j3vw
fuel pressure stays at 30ps... Aug 18 2010, 01:13 PM
realred914
fuel pressure stays at 30p... Aug 18 2010, 01:22 PM
underthetire I might add to remove the connector for the air in... Aug 18 2010, 12:26 PM
j3vw
I might add to remove the connector for the air i... Aug 18 2010, 01:08 PM
Bleyseng ok, have you put a vacuum gauge on it to see what ... Aug 18 2010, 05:31 PM
j3vw
ok, have you put a vacuum gauge on it to see what... Aug 18 2010, 05:36 PM
Bleyseng Hell, borrow a known good 037 ECU from somebody.. Aug 18 2010, 05:40 PM
j3vw
Hell, borrow a known good 037 ECU from somebody..... Aug 18 2010, 06:03 PM
Bleyseng its not a computer really its just a bunch of resi... Aug 18 2010, 06:45 PM
paws4862 Does your 73 have a Ballast Resistor in the system... Aug 19 2010, 12:02 PM
j3vw
Does your 73 have a Ballast Resistor in the syste... Aug 19 2010, 12:16 PM
Bleyseng
Does your 73 have a Ballast Resistor in the syst... Aug 19 2010, 01:21 PM
j3vw
[quote name='j3vw' post='1358294' date='Aug 19 20... Aug 20 2010, 12:51 PM
56kabrio
[quote name='j3vw' post='1358294' date='Aug 19 2... Aug 20 2010, 01:41 PM
paws4862 I don't know if you have this web site or not ... Aug 19 2010, 01:12 PM
j3vw
I don't know if you have this web site or not... Aug 19 2010, 01:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:21 AM |
