> Spring in the distrib drive, Needed?
jeffdon
post Aug 18 2010, 08:21 AM
Have a feeling I did not install a spring between the Distrib, and the Distrib Pinion gear/drive. Do not see it in the Raby video, but its in the factory parts schematic. I am running an 050 (i think, its not an 009) mech. adv. distrib. Do I need to put the spring in?
jeffdon
post Aug 18 2010, 10:03 AM
allrighty, i can pull the dizzy up about half an inch. The rotor is spinning freely, so I am betting that its pulling out of the drive slot, and the pinion is staying put, hence, the washer should not be able to fall. I hope.
However, the dizzy seems to be binding beyond that. WTF? Any tricks to coerce it out of there?
realred914
post Aug 18 2010, 10:20 AM
Group: Retired Members
QUOTE(jeffdon @ Aug 18 2010, 09:03 AM) *
give a good yank. also helps if the clamp for the dizzie is removed via the stud/nut on teh case, so the clamp pulls out with thte dizzie. if you try to pull th e dizzie thru the clamp it will hang up on the o-ring. so remove the clamp with the dizzie, shoudl yank right on out.
good luck
jeffdon
post Aug 18 2010, 10:24 AM
QUOTE(realred914 @ Aug 18 2010, 09:20 AM) *
good luck
got it, but the clamp was interfering with the tin, dammit, so it stayed on. Good news is the drive gear stayed in the case, so the washer stayed put. Now i am afraid to pull up the fear to re-index, lol. I KNOW how the diz is configured out of standard position, whats the harm in leaving it that way? I have no intention of passing the car onto anyone.
Can the gear be pulled just to the point where you can re-index it, but not far enough that the washer could drop off?
ME733
post Aug 18 2010, 10:52 AM
QUOTE(jeffdon @ Aug 18 2010, 12:24 PM) *
good luck
..................good question, I don't know.(but I doubt it).....I ALWAYS ..find TDC #1 cylinder, check distributor drive tang orentation...check distributor drive tang orentation...do a "dry run" for assembly (WITH OUT THE WASHER OR SPRING)...as... as the drive gears mesh it will rotate the distributor drive shaft ..ROTOR....which should wind up pointing to the nose of the crank shaft./or about 10-to 11 o'clock.....THEN AND only then do I grease up everything and assemble......
jeffdon   Spring in the distrib drive   Aug 18 2010, 08:21 AM
ME733   ..........YES ABSOLUTELY PUT THE SPRING IN...........   Aug 18 2010, 08:53 AM
realred914   ..........YES ABSOLUTELY PUT THE SPRING IN..........   Aug 18 2010, 09:00 AM
Mark Henry   ..........YES ABSOLUTELY PUT THE SPRING IN.........   Aug 18 2010, 09:04 AM
jeffdon   ..........YES ABSOLUTELY PUT THE SPRING IN..........   Aug 18 2010, 09:00 AM
ME733   ..........YES ABSOLUTELY PUT THE SPRING IN.........   Aug 18 2010, 09:15 AM
jeffdon   [quote name='jeffdon' post='1357769' date='Aug 18...   Aug 18 2010, 09:23 AM
ME733   [quote name='jeffdon' post='1357769' date='Aug 18...   Aug 18 2010, 09:27 AM
jeffdon   ..................Oh Dear God, protect this poor ...   Aug 18 2010, 09:36 AM
jeffdon   One more thing....i KNOW i somehow indexed the dri...   Aug 18 2010, 09:11 AM
realred914   yeah index it right so as to not screw up timing s...   Aug 18 2010, 09:34 AM
jeffdon   allrighty, i can pull the dizzy up about half an i...   Aug 18 2010, 10:03 AM
realred914   allrighty, i can pull the dizzy up about half an ...   Aug 18 2010, 10:20 AM
jeffdon   allrighty, i can pull the dizzy up about half an...   Aug 18 2010, 10:24 AM
ME733   [quote name='realred914' post='1357814' date='Aug...   Aug 18 2010, 10:52 AM
Vacca Rabite   Okay, a couple of things. if you loose the spring...   Aug 18 2010, 10:52 AM
jeffdon   Okay, a couple of things. if you loose the sprin...   Aug 18 2010, 10:59 AM
jeffdon   Okay, a couple of things. if you loose the spri...   Aug 18 2010, 11:27 AM
rhcb914   Nothing is wrong with running the dizzy 180 out. ...   Aug 18 2010, 12:32 PM
jeffdon   Nothing is wrong with running the dizzy 180 out. ...   Aug 18 2010, 03:21 PM
Vacca Rabite   On mine I like to gently tap on the locking collar...   Aug 18 2010, 05:33 PM
jeffdon   On mine I like to gently tap on the locking colla...   Aug 18 2010, 09:25 PM
charliew   You probably don't want to hear this but now t...   Aug 20 2010, 12:04 PM
ME733   You probably don't want to hear this but now ...   Aug 20 2010, 07:55 PM
- Lo-Fi Version Time is now: 4th March 2026 - 01:08 PM
