> Spring in the distrib drive, Needed?
jeffdon
post Aug 18 2010, 08:21 AM
Have a feeling I did not install a spring between the Distrib, and the Distrib Pinion gear/drive. Do not see it in the Raby video, but its in the factory parts schematic. I am running an 050 (i think, its not an 009) mech. adv. distrib. Do I need to put the spring in?
VaccaRabite
post Aug 18 2010, 10:52 AM
En Garde!
Okay, a couple of things.
if you loose the spring or the dizzy into the case, it is not the end of the world, especially if you have not put the engine in the car. The only place they can fall is down right next to the sump. If it happens, just pull the oil pump and retrieve your errant hardware. Of course take care NOT to have that happen, but don't let yourself wig out too much about it. I was able to retieve the spring this way with the engine in the car. Not fun, but not horrible.
For the indexing - do you think that your current gear index is wrong? If it was correct before you pulled the dizzy (and if you followed Jakes steps, it was right) then it will still be right now. The drive tang is off set on the dizzy and only fits in one way. As long as you don't remove the drive gear, your dizzy will be fine when you reinstall it.
But, if you are concerned about the drive gear being wrong, go ahead and pull it. Set the engine back to TDC and replace the drive and dizzy to the correct point as per Jake's video.
Zach
jeffdon   Spring in the distrib drive   Aug 18 2010, 08:21 AM
ME733   ..........YES ABSOLUTELY PUT THE SPRING IN...........   Aug 18 2010, 08:53 AM
realred914   ..........YES ABSOLUTELY PUT THE SPRING IN..........   Aug 18 2010, 09:00 AM
Mark Henry   ..........YES ABSOLUTELY PUT THE SPRING IN.........   Aug 18 2010, 09:04 AM
jeffdon   ..........YES ABSOLUTELY PUT THE SPRING IN..........   Aug 18 2010, 09:00 AM
ME733   ..........YES ABSOLUTELY PUT THE SPRING IN.........   Aug 18 2010, 09:15 AM
jeffdon   [quote name='jeffdon' post='1357769' date='Aug 18...   Aug 18 2010, 09:23 AM
ME733   [quote name='jeffdon' post='1357769' date='Aug 18...   Aug 18 2010, 09:27 AM
jeffdon   ..................Oh Dear God, protect this poor ...   Aug 18 2010, 09:36 AM
jeffdon   One more thing....i KNOW i somehow indexed the dri...   Aug 18 2010, 09:11 AM
realred914   yeah index it right so as to not screw up timing s...   Aug 18 2010, 09:34 AM
jeffdon   allrighty, i can pull the dizzy up about half an i...   Aug 18 2010, 10:03 AM
realred914   allrighty, i can pull the dizzy up about half an ...   Aug 18 2010, 10:20 AM
jeffdon   allrighty, i can pull the dizzy up about half an...   Aug 18 2010, 10:24 AM
ME733   [quote name='realred914' post='1357814' date='Aug...   Aug 18 2010, 10:52 AM
Vacca Rabite   Okay, a couple of things. if you loose the spring...   Aug 18 2010, 10:52 AM
jeffdon   Okay, a couple of things. if you loose the sprin...   Aug 18 2010, 10:59 AM
jeffdon   Okay, a couple of things. if you loose the spri...   Aug 18 2010, 11:27 AM
rhcb914   Nothing is wrong with running the dizzy 180 out. ...   Aug 18 2010, 12:32 PM
jeffdon   Nothing is wrong with running the dizzy 180 out. ...   Aug 18 2010, 03:21 PM
Vacca Rabite   On mine I like to gently tap on the locking collar...   Aug 18 2010, 05:33 PM
jeffdon   On mine I like to gently tap on the locking colla...   Aug 18 2010, 09:25 PM
charliew   You probably don't want to hear this but now t...   Aug 20 2010, 12:04 PM
ME733   You probably don't want to hear this but now ...   Aug 20 2010, 07:55 PM
- Lo-Fi Version Time is now: 4th March 2026 - 11:51 AM
