| andrewb |
Aug 18 2010, 10:23 AM
Member ![]() ![]() Group: Members Posts: 114 Joined: 25-May 10 From: UK Member No.: 11,762 Region Association: None |
Hi - here are a few pics of my car which needs 'quite a lot' of work.
![]() ![]() The immediate problem I'm trying to solve is this - the drivers side door gap - at the forward edge. ![]() There is no adjustment that I can see (i.e. no shims on the hinge mount) which can only mean that the front wing (sorry, fender) is 'out'. As far as I can tell it is the original. My questions are 1. Would it have left the factory like that ? I've read that tolerances were a bit slack by todays standards. The door gap on the drivers side is about 4mm more than on the passengers side. It hangs low by about 5mm when open but lines up perfectly when closed. There is no discernable play in the hinges. The door does shut with a liitle resistance but does not open and close as freely as the passenger side. Gaps on that side are a steady and even 2 to 3 mm front and back. Roll bar to windscreen frame dimensions are equal side to side within 1mm and do not change when the doors are open. The doors are the same size. 2. If it didn't leave the factory like that - what has caused it ? The car has had a light knock on the left front corner which I will show in my next post but the damage doesn't appear to extend any further back than where the inner wheel arch meets the bulkhead between the fuel tank and spare wheel well. The inner longs are completely shot both sides, the inner INNER longs are shot up to about 2" above the floor, the floors are fairly bad and the hell hole is good. I'll show all this with future pics. 3. Can I put it right and if so how ? Again - more pictures following will help you to decide. Thanks in advance. The knowledge on this forum is priceless. |
| andrewb |
Aug 18 2010, 11:06 AM
Wow ! replies to my first post from McMark AND George. Thanks for the input.
Realred - you're right, there are probably less than 200 cars in the UK - it makes me weep to see what you throw away or sell for peanuts in Ca. I've seen a few threads about crash damage having other than expected effects (Rick 918 sorted out a car which needed pulling downwards at the front and that squared it up in other areas) so I'm now thinking that is the first thing to tackle and see what happens. Has the frontal impact also pushed the front end sideways and therefore pulled the wing(fender) away from the door ? I'm off to do some more measuring and then to bolt a shackle to the garage floor. As a back up plan I do have this ![]() but I'd like to solve the problem without using it. One of the (many) next jobs is this ![]() |
andrewb Door fit problems - or worse. Aug 18 2010, 10:23 AM
dr914@autoatlanta.com doesn't look so bad to me! Remember thes... Aug 18 2010, 10:39 AM
realred914 hard to say what is wrong, lot of things can cuase... Aug 18 2010, 10:42 AM
McMark Generally that gap only gets bigger from some sort... Aug 18 2010, 10:43 AM
andrewb This is the evidence of the damage at the front.
... Aug 18 2010, 10:50 AM
bandjoey That does look like a wider than normal gap in the... Aug 18 2010, 10:59 AM
andrewb
Also add your vin# to the database here if you ... Aug 20 2010, 03:19 PM
Tom_T
I wouldn... Aug 18 2010, 01:15 PM
realred914
I would... Aug 18 2010, 01:27 PM
McMark This looks like evidence of replacement. Better p... Aug 18 2010, 11:06 AM
andrewb
This looks like evidence of replacement. Better ... Aug 18 2010, 11:11 AM
andrewb
This looks like evidence of replacement. Better... Aug 18 2010, 11:35 AM
andrewb
This looks like evidence of replacement. Better ... Aug 20 2010, 03:02 AM
jmill It sounds like you were eyeballing my thread. If ... Aug 18 2010, 11:20 AM
andrewb
It sounds like you were eyeballing my thread. I... Aug 18 2010, 11:34 AM
andrewb
It sounds like you were eyeballing my thread. If... Aug 19 2010, 02:37 AM
jmill If it were me I wouldn't concern myself with t... Aug 18 2010, 12:06 PM
70_914 Those stripes look pretty good... :idea:
Are ... Aug 18 2010, 02:27 PM
andrewb
Are... Aug 19 2010, 02:06 AM
veltror Another rusty one in the UK being brought back to ... Aug 19 2010, 06:29 AM
einic My 72 914 also have this uneven openings. And: the... Aug 19 2010, 06:44 AM
rick 918-S :wttc: You have a real challenge ahead of you. Th... Aug 19 2010, 07:52 AM
Tom Andrewb, :wttc:
Quite the project you have ... Aug 19 2010, 07:55 AM
rick 918-S Measure down the wire and set up a cross bar.
... Aug 19 2010, 07:59 AM
charliew I also think Rick is dead on. You can probably jus... Aug 19 2010, 06:43 PM
andrewb
I really think it's the way it is supported o... Aug 20 2010, 02:44 AM
rick 918-S I would fix the floors and longs and fit the doors... Aug 20 2010, 11:46 AM
andrewb Message received Rick. Drivers side long is first ... Aug 20 2010, 03:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd November 2026 - 03:39 PM |
