| j3vw |
Aug 18 2010, 09:28 AM
Newbie ![]() Group: Members Posts: 14 Joined: 18-August 10 From: columbia TN Member No.: 12,066 Region Association: None |
Hey Folks...little help?.......73 1.7...idles pefect, ignition system and valves good.....idle air fuel mix fine...over aprox 2500 rpm....leans out bad...tested press sensor, vac.. good resistance good...all indicators are full load enrichment not happening...any ideas?...I do alot of L-jet work and ECU"s are rarely the problem..
Thanks! Rich |
| Bleyseng |
Aug 18 2010, 12:22 PM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
and the ECU is a 037?
fuel pressure stays at 30psi when you rev the engine? The WOT stop (big slotted plug) must come out and to do that you remove all the epoxy with a heat guy and dental picks. I am still thinking something is wrong as "IF" you have all the correct FI parts and they are working then its a fuel or spark issue. The Djet stuff is hardwired so if they are the right years and engine setup it works, no magic to it. If you change the engine size or other things, yeah its gonna be off. Check your fuel pressure to see what it is running. See what happens when you turn it up to 36lbs.... |
j3vw Help Need D-jet Jedi! Aug 18 2010, 09:28 AM
realred914
Hey Folks...little help?.......73 1.7...idles pef... Aug 18 2010, 09:37 AM
j3vw
Hey Folks...little help?.......73 1.7...idles pe... Aug 18 2010, 09:44 AM
Bleyseng check out the TPS and also how do you know its lea... Aug 18 2010, 10:00 AM
j3vw
check out the TPS and also how do you know its le... Aug 18 2010, 10:07 AM
Bleyseng What is the number on the MPS? Aug 18 2010, 10:15 AM
j3vw
-100 049
cyl h... Aug 18 2010, 10:27 AM
Bleyseng Untampered with? meaning factory unit with the epo... Aug 18 2010, 10:46 AM
Bleyseng Untampered with? meaning factory unit with the epo... Aug 18 2010, 10:47 AM
j3vw
Untampered with? meaning factory unit with the ep... Aug 18 2010, 10:59 AM
j3vw
fuel pressure stays at 30ps... Aug 18 2010, 01:13 PM
realred914
fuel pressure stays at 30p... Aug 18 2010, 01:22 PM
underthetire I might add to remove the connector for the air in... Aug 18 2010, 12:26 PM
j3vw
I might add to remove the connector for the air i... Aug 18 2010, 01:08 PM
Bleyseng ok, have you put a vacuum gauge on it to see what ... Aug 18 2010, 05:31 PM
j3vw
ok, have you put a vacuum gauge on it to see what... Aug 18 2010, 05:36 PM
Bleyseng Hell, borrow a known good 037 ECU from somebody.. Aug 18 2010, 05:40 PM
j3vw
Hell, borrow a known good 037 ECU from somebody..... Aug 18 2010, 06:03 PM
Bleyseng its not a computer really its just a bunch of resi... Aug 18 2010, 06:45 PM
paws4862 Does your 73 have a Ballast Resistor in the system... Aug 19 2010, 12:02 PM
j3vw
Does your 73 have a Ballast Resistor in the syste... Aug 19 2010, 12:16 PM
Bleyseng
Does your 73 have a Ballast Resistor in the syst... Aug 19 2010, 01:21 PM
j3vw
[quote name='j3vw' post='1358294' date='Aug 19 20... Aug 20 2010, 12:51 PM
56kabrio
[quote name='j3vw' post='1358294' date='Aug 19 2... Aug 20 2010, 01:41 PM
paws4862 I don't know if you have this web site or not ... Aug 19 2010, 01:12 PM
j3vw
I don't know if you have this web site or not... Aug 19 2010, 01:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:59 AM |
