Alternator help, just a few questions |
weird_looking_cactus |
Mar 17 2004, 12:14 PM
Cactus Group: Members Posts: 225 Joined: 16-February 04 From: St, George UT Member No.: 1,660 |
Well my battery is not charging up when the car is started so Im thinking my alternator is bad. I want to take it out so I can go have it tested. I have looked at the articals at pelicans but Im still lost on were the alternator is located some pictures would be great.
type47 |
Mar 17 2004, 12:23 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
(assuming you have a 914).... the alternator is at the front left of the engine (as if you were looking from the rear to the front of the car) sorta directly behind the drivers butt. remove little plastic covers over the slits in the tin to access the alt tension bolt. loosen bolt. remove engine sheet metal, front left part to access alt. remove wiring to alt. unbolt alt. remove cooling duct to fan housing. ... um.... remove alt. install is reverse.
better to follow the tech article. |
Lo-Fi Version | Time is now: 1st June 2024 - 11:59 AM |
