Alternator help, just a few questions |
weird_looking_cactus |
Mar 17 2004, 12:14 PM
Cactus Group: Members Posts: 225 Joined: 16-February 04 From: St, George UT Member No.: 1,660 |
Well my battery is not charging up when the car is started so Im thinking my alternator is bad. I want to take it out so I can go have it tested. I have looked at the articals at pelicans but Im still lost on were the alternator is located some pictures would be great.
tat2dphreak |
Mar 17 2004, 12:27 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
you'll have to pull the engine... at LEAST part way... I am pretty sure of that...
it's located next to the impeller fan, held by 2 bolts... have you picked up a haynes manual? I advise it, it will really help you out when pulling it... there is a way to test your alt. without pulling it though... using a multimeter... someone else here I'm sure has the specifics... where to hook up, what the readings should be... or you can pull the altenator and take it to an autozone... they can test it there... the BUS altenator may be a direct swap(cheaper, easier to find) |
Lo-Fi Version | Time is now: 7th June 2024 - 10:31 PM |
