Megasquirt & Fuel pump woes |
3d914 |
Mar 16 2004, 06:51 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Hey all you Squirters,
I finally finished the new wiring harness for the ECU & relay board on my MS install. Did any of you have to bypass the stock Fuel pump relay to use the MS relay board's fuel pump relay? Initially for fuel pump control I ran the #19 wire from the white connector on the stock relay board to the MS ECU. Now that I'm using the MS relay board, my fuel pumps not coming on when connected to it. Fuse checks out, and if I run the single ground wire for the FP to engine ground instead of the MS relay board - FP runs fine. Any thoughts? TIA |
crash914 |
Mar 17 2004, 12:36 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
On mine, I left the wiring stock from the relay board to the fuel pump.
On the megasquirt relay board, no connection to any of the terminals for the fuel pump. Now, I did have the ecu plugged in to the harness...I am not sure where the fuel pump gets its 3 second delay. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:53 PM |
