Alternator help, just a few questions |
weird_looking_cactus |
Mar 17 2004, 12:14 PM
Cactus Group: Members Posts: 225 Joined: 16-February 04 From: St, George UT Member No.: 1,660 |
Well my battery is not charging up when the car is started so Im thinking my alternator is bad. I want to take it out so I can go have it tested. I have looked at the articals at pelicans but Im still lost on were the alternator is located some pictures would be great.
davep |
Mar 17 2004, 12:49 PM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Before you start yanking the alternator, there are a few things to check first.
Is the alternator belt tight or even present. Is the voltage regulator, screwed to the side of the relay board functional. The 3 prong connector that plugs into the relay board will plug directly into the regulator. That can eliminate a bad relay board. Try a known good regulator. There is a lot of information in other threads (do a search on alternator) on electrical tests. If the alternator has not been out in years, you may have a lot of problems getting at it. The screws for the sheet metal can be a real pain. Carefully note all the parts as you take them out to know how they have to go back in. DaveP |
Lo-Fi Version | Time is now: 7th June 2024 - 10:41 PM |
