| 7TPorsh |
Aug 20 2010, 09:13 AM
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California
I have a bunch of little weird electrical things going on...so i'll attack one at a time:
The fuel gauge (stock combo gauge) moves as follows under different conditions: - Ignition off/headlights on- turning headlight knob up makes fuel gauge go from empty to full; turning down go back to empty. - Ignition on/headlights on- fuel gauge show reading...turning knob up increases the reading on the fuel gauge by 1/4 tank; turning down decreases...so 1/4 fluctuation in the fuel gauge depending on how the headlight knob is turned. Tend to think the full bright on the headlights translates to a closer fuel reading. But why? is the power source for the fuel gauge incorrect? I checked the schematic, but it looks like a Lucas engineer designed the wiring for the combo gauge. |
| 7TPorsh |
Aug 20 2010, 11:37 AM
I think it has always done this and I just discovered it now that i want to start driving the car after 5 years on jackstands.
I'll check the grounds...which is the power wire? Hard to tell from the schematic...any pics? I have a feeling the power is being sourced from the dash lights and not the fuse box. |
7TPorsh Weird Electrical Happenings-Part 1 Aug 20 2010, 09:13 AM
Cap'n Krusty Check your grounds, then use the wiring diagram to... Aug 20 2010, 09:29 AM
realred914
I have a bunch of little weird electrical things ... Aug 20 2010, 10:36 AM
Tom Did this just start after you made some repairs/mo... Aug 20 2010, 11:33 AM
Tom Since it has been sitting for a while, I would exp... Aug 20 2010, 12:05 PM
kg6dxn Electrical systems will do strange things when a g... Aug 20 2010, 01:07 PM
Tom Mike,
Very well put. Exactly what I was thinki... Aug 20 2010, 01:11 PM
7TPorsh Where are the ground connections points? Diagram s... Aug 20 2010, 01:49 PM
kg6dxn
Where are the ground connections points? Diagram ... Aug 20 2010, 02:58 PM
7TPorsh Well i checked around...behind the front trunk pul... Aug 27 2010, 12:06 PM
realred914
Well i checked around...behind the front trunk pu... Aug 27 2010, 12:42 PM
kg6dxn There is a dash light that illuminates with the pa... Aug 27 2010, 01:07 PM
7TPorsh
There is a dash light that illuminates with the p... Aug 27 2010, 02:00 PM
kg6dxn
There is a dash light that illuminates with the ... Aug 27 2010, 02:44 PM
realred914
There is a dash light that illuminates with the ... Aug 27 2010, 02:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th October 2026 - 10:13 AM |
