> engine warm up, rough running till warm
simonr
post Aug 19 2010, 04:11 PM
I have a 1976 stock FI 2.0 with 128,000 miles on her. ive had the car 2 months and have gone thru her pretty well because im a stckler for knowing where im at with my Porsches. I have replaced all vacuum hoses points, plugs , adjusted valves and timing is dead on. I live in Indiana so its not been cold yet. My car runs fine after she warms up but does not run well at all until then . She idles but going through the gears she surges pops and farts for about 5 to ten minutes of run time then she runs great. are the 914's usually this cold blooded. I dread to think what it will be like when it starts getting chilly out. Am I expecting too much? I just feel im missing something. Thanks for all imput
simonr
post Aug 20 2010, 11:49 AM
I pulled the aar and have it soaking. it was stuck half way open . I freed it up and now giving it a good soak. Ill reinstall tomorrow and see how it does.
simonr   engine warm up   Aug 19 2010, 04:11 PM
underthetire   Is the AAR working?   Aug 19 2010, 04:32 PM
simonr   Im not sure How do I check it?   Aug 19 2010, 05:21 PM
Jeffs9146   Take it off and blow through it then touch it to g...   Aug 19 2010, 05:42 PM
underthetire   wow, thats a lot of words. Does it idle at about ...   Aug 19 2010, 06:23 PM
Jeffs9146   :lol4: Luckly I didn't have to write them...   Aug 19 2010, 06:31 PM
simonr   The car idles right at 900 to 1000 upon start up ....   Aug 20 2010, 04:35 AM
simonr   The AAR has strong vucuum pull upon cold start up ...   Aug 20 2010, 06:23 AM
vsg914   Where does it idle after warmup?   Aug 20 2010, 06:42 AM
simonr   Where does it idle after warmup? It idles right ...   Aug 20 2010, 07:47 AM
underthetire   Ok, so if it has strong vacuum at start up, then i...   Aug 20 2010, 08:42 AM
Tom   He said it has a strong vacuum upon cold start up....   Aug 20 2010, 11:43 AM
underthetire   He said it has a strong vacuum upon cold start up...   Aug 20 2010, 12:12 PM
simonr   I pulled the aar and have it soaking. it was stuc...   Aug 20 2010, 11:49 AM
Tom   Yep, that could be it. Tom   Aug 20 2010, 01:08 PM
simonr   I reinstalled the AAR and noticed no change The sl...   Aug 21 2010, 07:48 AM
Tom   Check Brad Anders 914 D-Jetronic parts and troubl...   Aug 21 2010, 10:30 AM
avidfanjpl   Yep Sounds like a CHT problem Do you have the pr...   Aug 21 2010, 02:58 PM
simonr   I replaced the CHT sensor with the stock unit . Ma...   Aug 21 2010, 03:39 PM
underthetire   The extension piece helps with warm up, it was a a...   Aug 21 2010, 05:05 PM
simonr   I do not have a high rpm at start up its about 100...   Aug 21 2010, 07:31 PM
underthetire   well, mine used to open around 80 deg that I could...   Aug 22 2010, 04:46 PM
simonr   Put aar in freezer for half an hour . It opened wi...   Aug 24 2010, 04:22 PM
- Lo-Fi Version Time is now: 30th April 2026 - 08:30 PM
