> Valves on new rebuild, When to re-adjust
jeffdon
post Aug 21 2010, 11:21 AM
Been driving with the new engine, and probably have all of an hour and a half behind the wheel. The engine has quite the clattering noise that I notice at idle, which I assume is the valves. I set (and re-set) them three times before it went in the car. My webcam 494 spec card showed to set both valves to .006. I went with .007, based on the common thinking that its better to be a little loose. I am running stock push rods.
Just climbed under the car thinking to check the valves, and am really not looking forward to this. I have set them with the engine in the car in the past, and cannot recall it being such a crappy job.
I guess my question boils down to this:
Should I put more road time on the car before adjusting the valves? Or am I better off letting things break in more before doing the adjust. I am thinking if the valves are making noise, they may be loose, which is way better than too tight, allthough the performance would be down.
Whats all ya'lls consensus?
Cap'n Krusty
post Aug 21 2010, 11:44 AM
Cap'n Krusty
First off, loose is safer, but NOT better, as it can cause wear on the valve tips and the adjusters. Not likely on break in, or over a short time, but the possibility is there. Next, we always adjust the valves after the engine has been run at 1500-2000 RPM for 30 minutes and the dwell and timing has been checked (in that order). After that, we do it again at 300 miles, then 1500 and 3000. After that, every 3000 miles, along with the oil change service. We've been doing engine break-ins here for close to 40 years, and it works for us. The initial hot run-in is extremely important for cam and lifter life! During that time, you shouldn't allow the engine to return to idle. We've found the valve adjustments are often all over the place at the first adjustment, but not always.
The Cap'n
- Lo-Fi Version Time is now: 1st October 2026 - 09:38 AM
