> Valves on new rebuild, When to re-adjust
jeffdon
post Aug 21 2010, 11:21 AM
Been driving with the new engine, and probably have all of an hour and a half behind the wheel. The engine has quite the clattering noise that I notice at idle, which I assume is the valves. I set (and re-set) them three times before it went in the car. My webcam 494 spec card showed to set both valves to .006. I went with .007, based on the common thinking that its better to be a little loose. I am running stock push rods.
Just climbed under the car thinking to check the valves, and am really not looking forward to this. I have set them with the engine in the car in the past, and cannot recall it being such a crappy job.
I guess my question boils down to this:
Should I put more road time on the car before adjusting the valves? Or am I better off letting things break in more before doing the adjust. I am thinking if the valves are making noise, they may be loose, which is way better than too tight, allthough the performance would be down.
Whats all ya'lls consensus?
sean_v8_914
post Aug 21 2010, 12:18 PM
Chingon 601
Krusty knows best.
what pistons are you running? size? brand?
- Lo-Fi Version Time is now: 1st October 2026 - 09:38 AM
