> engine warm up, rough running till warm
simonr
post Aug 19 2010, 04:11 PM
I have a 1976 stock FI 2.0 with 128,000 miles on her. ive had the car 2 months and have gone thru her pretty well because im a stckler for knowing where im at with my Porsches. I have replaced all vacuum hoses points, plugs , adjusted valves and timing is dead on. I live in Indiana so its not been cold yet. My car runs fine after she warms up but does not run well at all until then . She idles but going through the gears she surges pops and farts for about 5 to ten minutes of run time then she runs great. are the 914's usually this cold blooded. I dread to think what it will be like when it starts getting chilly out. Am I expecting too much? I just feel im missing something. Thanks for all imput
avidfanjpl
post Aug 21 2010, 02:58 PM
914 Hemophiliac
Yep
Sounds like a CHT problem
Do you have the proper one in the car.
There are wild differences, and my car runs a little rough in the first minute on the proper 017 CHT
The 012 runs well at the start, but after warmup, hunting problems and too rich.
017 is proper for my car, but the 270 Ohm resistor does not seem to make a difference.
John
simonr   engine warm up   Aug 19 2010, 04:11 PM
underthetire   Is the AAR working?   Aug 19 2010, 04:32 PM
simonr   Im not sure How do I check it?   Aug 19 2010, 05:21 PM
Jeffs9146   Take it off and blow through it then touch it to g...   Aug 19 2010, 05:42 PM
underthetire   wow, thats a lot of words. Does it idle at about ...   Aug 19 2010, 06:23 PM
Jeffs9146   :lol4: Luckly I didn't have to write them...   Aug 19 2010, 06:31 PM
simonr   The car idles right at 900 to 1000 upon start up ....   Aug 20 2010, 04:35 AM
simonr   The AAR has strong vucuum pull upon cold start up ...   Aug 20 2010, 06:23 AM
vsg914   Where does it idle after warmup?   Aug 20 2010, 06:42 AM
simonr   Where does it idle after warmup? It idles right ...   Aug 20 2010, 07:47 AM
underthetire   Ok, so if it has strong vacuum at start up, then i...   Aug 20 2010, 08:42 AM
Tom   He said it has a strong vacuum upon cold start up....   Aug 20 2010, 11:43 AM
underthetire   He said it has a strong vacuum upon cold start up...   Aug 20 2010, 12:12 PM
simonr   I pulled the aar and have it soaking. it was stuc...   Aug 20 2010, 11:49 AM
Tom   Yep, that could be it. Tom   Aug 20 2010, 01:08 PM
simonr   I reinstalled the AAR and noticed no change The sl...   Aug 21 2010, 07:48 AM
Tom   Check Brad Anders 914 D-Jetronic parts and troubl...   Aug 21 2010, 10:30 AM
avidfanjpl   Yep Sounds like a CHT problem Do you have the pr...   Aug 21 2010, 02:58 PM
simonr   I replaced the CHT sensor with the stock unit . Ma...   Aug 21 2010, 03:39 PM
underthetire   The extension piece helps with warm up, it was a a...   Aug 21 2010, 05:05 PM
simonr   I do not have a high rpm at start up its about 100...   Aug 21 2010, 07:31 PM
underthetire   well, mine used to open around 80 deg that I could...   Aug 22 2010, 04:46 PM
simonr   Put aar in freezer for half an hour . It opened wi...   Aug 24 2010, 04:22 PM
- Lo-Fi Version Time is now: 30th April 2026 - 08:30 PM
