| jeffdon |
Aug 21 2010, 11:21 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
Been driving with the new engine, and probably have all of an hour and a half behind the wheel. The engine has quite the clattering noise that I notice at idle, which I assume is the valves. I set (and re-set) them three times before it went in the car. My webcam 494 spec card showed to set both valves to .006. I went with .007, based on the common thinking that its better to be a little loose. I am running stock push rods.
Just climbed under the car thinking to check the valves, and am really not looking forward to this. I have set them with the engine in the car in the past, and cannot recall it being such a crappy job. I guess my question boils down to this: Should I put more road time on the car before adjusting the valves? Or am I better off letting things break in more before doing the adjust. I am thinking if the valves are making noise, they may be loose, which is way better than too tight, allthough the performance would be down. Whats all ya'lls consensus? |
| Mark Henry |
Aug 22 2010, 10:09 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
You might not have enough miles on it to check, lean plugs usually have a white electrode (the ceramic part). You need to drive for about 20min, turn off the key and coast to a stop and then check plugs. Do a Google search for the full instructions.
I now use a wideband to tune and jet, instant results and no pulling plugs. |
jeffdon Valves on new rebuild Aug 21 2010, 11:21 AM
Cap'n Krusty First off, loose is safer, but NOT better, as it c... Aug 21 2010, 11:44 AM
jeffdon
First off, loose is safer, but NOT better, as it ... Aug 21 2010, 11:52 AM
sean_v8_914 Krusty knows best.
what pistons are you running? s... Aug 21 2010, 12:18 PM
jeffdon
Krusty knows best.
what pistons are you running? ... Aug 21 2010, 12:52 PM
jeffdon [quote name='jeffdon' date='Aug 21 201... Aug 21 2010, 12:55 PM
Jake Raby The web recommendations do not consider the pushro... Aug 21 2010, 02:05 PM
jeffdon
The web recommendations do not consider the pushr... Aug 21 2010, 02:33 PM
Mark Henry Stock PR so run them at the .006
It's not goin... Aug 21 2010, 06:57 PM
jeffdon
It's not goi... Aug 22 2010, 08:17 AM
jeffdon
You might not have enough miles on it to check, l... Aug 22 2010, 10:23 AM
jeffdon
You might not have enough miles on it to check, ... Aug 22 2010, 04:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st October 2026 - 09:38 AM |
