| TheCabinetmaker |
Aug 21 2010, 08:22 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,365 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I've had the engine out of the car to fix some oil leaks and upon removing the flywheel, there was only two shims, and one of them was just about destroyed. Does anyone see anything wrong with this pic? (besides the oil everywhere!) (IMG:http://www.914world.com/bbs2/uploads_offsite/i290.photobucket.com-666-1282443773.1.jpg) |
| Mark Henry |
Aug 22 2010, 01:37 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Your trust is fuched, tear down time.
If you can't get it to spec with 3 shims you're done, 4 shims and the crank throw will hit a main bearing web. If you're lucky it's just the bearing, if not it's a line bore and bearings with an OS thrust. |
vsg914 end play gone wrong? Aug 21 2010, 08:22 PM
vsg914 47 views and no comments? You guys are slipping. Aug 22 2010, 10:40 AM
BMXerror
... Aug 22 2010, 10:46 AM
Bartlett 914 Hard to tell from the picture but it looks like a ... Aug 22 2010, 01:11 PM
vsg914
Hard to tell from the picture but it looks like a... Aug 22 2010, 01:32 PM
vsg914 I did check end play with no shims. it measured 2.... Aug 22 2010, 01:30 PM
vsg914 Good eye Mark! The end of the thrust that lips... Aug 22 2010, 01:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 09:18 PM |
