> Best time to check engine oil level on my 914?
recko911
post Aug 21 2010, 06:48 PM
Is it best to check engine oil level when vehicle is cold, or should I warm it up for 5 min then check in 3 min. What do you guys think?
1970 Neun vierzehn
post Aug 22 2010, 07:34 PM
From a 1970 /4 owners manual:
"The oil level should be between the two marks on the dipstick, and must never sink below the lower mark. An exact indication is only possible if the car is standing level. It is wrong to check the oil immediately after switching off the engine-the oil needs a few minutes to flow back into the crankcase. When the engine has to carry out particularly heavy work, such as on long turnpike trips in summer, the oil level should be kept just under the upper mark."
"Pull out dipstick and wipe with a clean rag. Push in dipstick to stop, pull out again and read off oil level. The distance between the upper and lower marks corresponds to approx. 2.1 US pints/1.8 Imp. pints."
recko911   Best time to check engine oil level on my 914?   Aug 21 2010, 06:48 PM
Mark Henry   /6 warm and running. A /4 hot or cold, shut off a...   Aug 21 2010, 07:09 PM
bandjoey   If I check mine hot it's always 1 mark too hig...   Aug 21 2010, 08:52 PM
1970 Neun vierzehn   As Mark said, always have the car on level ground....   Aug 22 2010, 11:05 AM
ME733   .ON level ground ...Hot and running......this is t...   Aug 22 2010, 11:31 AM
vsg914   .ON level ground ...Hot and running......this is ...   Aug 22 2010, 11:59 AM
ME733   .ON level ground ...Hot and running......this is...   Aug 23 2010, 09:36 AM
realred914   [quote name='vsg914' post='1359604' date='Aug 22 ...   Aug 23 2010, 09:50 AM
ME733   [quote name='vsg914' post='1359604' date='Aug 22 ...   Aug 23 2010, 10:11 AM
1970 Neun vierzehn   From a 1970 /4 owners manual: "The oil level...   Aug 22 2010, 07:34 PM
McMark   Check it with the engine off like most everyone, i...   Aug 22 2010, 08:47 PM
vsg914   "IF you check a 911,s oil level while it,s ru...   Aug 23 2010, 10:09 AM
ME733   "IF you check a 911,s oil level while it,s r...   Aug 23 2010, 10:15 AM
vsg914   "IF you check a 911,s oil level while it,s ...   Aug 23 2010, 10:51 AM
ME733   [quote name='ME733' post='1360043' date='Aug 23 2...   Aug 23 2010, 10:58 AM
McMark   :agree: Dry sump vs. wet sump. Dave is also righ...   Aug 23 2010, 10:12 AM
tradisrad   I've got an external oil cooler and that chang...   Aug 23 2010, 10:21 AM
dflesburg   Just as long as you do check it. How about every ...   Aug 23 2010, 11:02 AM
Sleepin   Just as long as you do check it. How about every...   Aug 23 2010, 01:07 PM
vsg914   The 4 cylinder factory specs says "3.5 litres...   Aug 23 2010, 11:08 AM
7TPorsh   MISERABLE 4...geez!   Aug 23 2010, 12:17 PM
recko911   Thanks guys for the advice! If the engine is o...   Aug 24 2010, 11:39 PM
URY914   Another simple question followed by everyone's...   Aug 25 2010, 05:12 PM
black73   > Best time to check engine oil level on my 914...   Aug 25 2010, 05:53 PM
bandjoey   Now that you get to pick when to check the oil (co...   Aug 25 2010, 10:25 PM
charliew   It's been a long time but I think I remember w...   Aug 26 2010, 03:24 PM
Root_Werks   Ah crap.....when I pull the dipstick out of my L-J...   Aug 26 2010, 04:36 PM
- Lo-Fi Version Time is now: 11th October 2026 - 08:39 AM
