| stateofidleness |
Aug 22 2010, 04:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 810 Joined: 1-September 07 From: Canyon Lake, Texas! Member No.: 8,065 Region Association: None |
at my wit's end with brake bleeding (who else says "blake breeding" on accident?... ok just me (IMG:style_emoticons/default/smile.gif)) anyways...
tried the old fashioned "get a buddy" method... this helped me find all my leaks... fun.. so after replacing all the lines, the master cylinder and a rear caliper, we tried again (3 weekends into this so far... ) Builds a little pressure, go to next wheel.. try again.. no change, but good flow.. after doing all 4 corners and getting good flow with no air at each one, STILL pedal almost goes all the way to the floor with little pressure... finally got to that point where you don't mind spending money to make the process easier, so i went to FLAPS and got the MityVac thing... $40 later i get home and go back to work... got the process down and got good flow at each tire again, reservoir staying full throughout... STILL sh*tty pedal feel... so at the time of this writing.. i quit! |
| pcar916 |
Aug 23 2010, 07:55 AM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
Best price is at Racer Wholesale Parts.
http://www.racerpartswholesale.com/categor..._Brake_Bleeders Call 'em for your car. They'll know the part number for your Porsche cap. I'm not near mine so I can't get the part number for you. Note: If you get the universal kit with all of the adapters, you can do all of the cars and trucks you own. This is the only way to do an ABS system BTW. If the fluid level goes down to low on those systems you have to fiddle with the computer as well as the mechanical stuff. |
stateofidleness Brake bleeding... Aug 22 2010, 04:14 PM
Spoke Hows the venting clearance of the rear brakes? If ... Aug 22 2010, 04:48 PM
9146986 I too tried the MityVac, and it just doesn't w... Aug 22 2010, 05:21 PM
Vacca Rabite If you have speed bleeders, try the long tube meth... Aug 22 2010, 07:04 PM
swl must add a me too to the vacuum not working. Just... Aug 22 2010, 07:37 PM
930cabman
must add a me too to the vacuum not working. Jus... Jun 3 2021, 08:16 AM
davesprinkle The long tube method saved my marriage, no joke. ... Aug 22 2010, 07:43 PM
stateofidleness dammit, i thought the MityVac one was THE one, and... Aug 22 2010, 07:44 PM
Vacca Rabite
also, i have one rear caliper that has 2 valves,... Aug 23 2010, 06:57 AM
stateofidleness would this one work on the 914: http://www.autopar... Aug 22 2010, 07:57 PM
stateofidleness oh, i was following the pelican article:
"If... Aug 23 2010, 07:13 AM
pcar916
"I... Aug 23 2010, 07:32 AM
twistedstang
... Apr 5 2019, 09:55 AM
Garland
1. Bleed nipples are always on top. Air bubbles ... Jul 21 2020, 07:19 PM
stateofidleness think i'm gonna order the Motive, but not sure... Aug 23 2010, 07:37 AM
stepuptotheMike Don't even touch the bottom bleeder valve. Th... Aug 23 2010, 07:39 AM
stateofidleness ordered! got an email about a 10% discount the... Aug 23 2010, 07:55 AM
Vacca Rabite
Note: If you get the universal kit with all of th... Aug 23 2010, 07:59 AM
stateofidleness adapters can be purchased separate as needed right... Aug 23 2010, 08:05 AM
underthetire I've done brakes several times with the mighty... Aug 23 2010, 08:57 AM
Drums66
I've done brakes several times with the might... Aug 23 2010, 04:16 PM
jeffdon Don't forget to bleed the proportioning valve.... Aug 23 2010, 04:10 PM
Ductech Here is my two cents .... Yes these are all good m... Aug 23 2010, 04:26 PM
type47 Question I have is about setting the brake pedal d... Oct 8 2010, 09:59 AM
ctc911ctc All Brake GuRus, I have read all of the articles a... Apr 5 2019, 09:17 AM
76-914
All Brake GuRus, I have read all of the articles ... Apr 5 2019, 02:45 PM
mepstein I just crack the fittings at the mc instead of rem... Apr 5 2019, 10:03 AM
mlindner I just did mine after 25 years of all being apart.... Apr 7 2019, 06:57 AM
Superhawk996 I've had good luck in the past using a MightyV... Apr 7 2019, 10:31 AM
Ansbacher DON'T ignore bleeding those lower valves! ... Jun 3 2021, 11:42 AM
rhodyguy Adapting a larger container that could attach to t... Jun 3 2021, 11:59 AM
Al Meredith I think it has been mentioned here before but I re... Jun 3 2021, 03:52 PM
930cabman Our 1975 project was missing a rear caliper, both ... Jun 3 2021, 06:33 PM
andys When vacuum bleeding, I put grease around the thre... Jun 4 2021, 11:59 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:46 PM |
